Introduction: 15 Minute Crystals
Don't have time to wait 6 weeks to grow crystals? This ible will show you how to make some in 15 minutes on a small budget!
Step 1: Tools & Materials
Tools:
Glue gun
Lighter (optional)
Materials:
Aluminium foil
Glue gun glue sticks
Cooking spray
Clay (or other moldable material to create templates)
Step 2: Making Templates
Start by making some templates from clay, I chose to make four sided crystals that end in a point. Whatever shape you chose make sure they can be removed from the mould later on. The more templates you make the more choice you have for customizing the prop you intend to use them on!
Step 3: Making the Mould
Now wrap your template in aluminium foil and make sure to get all the corners. Once it fits snugly around the template gently pull the template out of the mould.
Step 4: Spraying
Give the inside of the mould a generous spraying of cooking spray to make sure the mould will come off later on. While waiting for the gas to bubble out of the cooking spray you can make some more moulds!
Step 5: Fill the Mold
Alright this step needs a bit of a warning label: CAUTION, HOT. You might want to wear gloves or find a good spot to set the mould down. Once you're sure you won't get burned, use your gluegun and fill up the mould.
Step 6: Unwrapping
When everything cools down, tear off the aluminium foil to reveal your cristal! If you dislike the wrinkles created by the aluminium foil, you can use a lighter to flame polish the surfaces.
Step 7: Finished
Now that your crystals are done you can use them by sticking them into a base or glue them onto a prop, I am using mine to make glowing crystals growing out of a staff for my girlfriends costume (if you stick a LED under them they will glow a dull yellow / white).
Halloween Decor Contest 2016
