Using my little high school desk for the whole summer was out of the question, so I decided to build a new one. Since I had a loft bed, I got the crazy idea to build a desk that would hang from said bed instead of resting on the floor. Surprisingly, it actually worked - and worked well! It was also super easy and quick to build.
Here are steps I took to build it. You can also view the original tutorial at my blog.
Remove these ads by
Signing UpStep 1Buy ALL THE MATERIALS
Materials:
- One 4ft x 2ft x 1in (or thicker) piece of hardboard (HDF) - not particle board
- Four sections of 4ft-long chain. I prefer Tenso chain, because its double-loop link design makes it really strong. It's also super cheap. Whatever you get, make sure it's rated to at least 150 pounds (the Tenso I bought is rated at 244).
- Rope. Any kind will do, though I'd personally avoid super thick rope. It won't be bearing any weight anyway.
- S-hooks, spring links, or a combination of both. You need 8 in total. I'm using a combination because Home Depot didn't have 8 of either in stock at the time.
Tools:
- A drill with a large drill bit. If you have a Forstner bit it'll be easier, but I got by with a standard twisted bit (college kids gotta make due)
That's it! In the next step we'll start the build process. You might notice that the picture of the board here already has holes in it; I forgot to snap a pic of it beforehand. Anyway, moving on...
Do you think it would be possible to, instead of using rope to secure the desk to ONE support, to install hinges on TWO supports? this way, the desk could be raised to hide it away..... just a thought, I might give it a try one of these years.......
Instead of using chain to hang it, you'd probably need to use rope or steel cable. Instead of looping the cables and attaching them to themselves at the top, I'd make them extra long and route them up and through to the back. Attach a series of strong hooks to the bed posts, and you'd be able to "link" the cables to them and get your desired height.
Then, replace the rope with another set of "hooks" - two attached to the back of the desk and point downward, and set of upward pointing hooks that they could "lock into" so the desk wouldn't swing.
It'd be a little more complicated this way, but I think it would work.
rather than looping the chain, I think it may work better if you use eye screws.
to keep the desk from swinging around and your expensive monitors crashing to the ground, you may want to add l-brackets to secure the desk to the bed frame legs.
I actually covered both of those points in this tutorial. In Step 2, I mention that you could use something to keep the chain from coming back out of the holes instead of looping it - I just didn't have eye bolts on hand when I was building it.
As for preventing the desk from swinging, that's the entire purpose of Step 3 :)
