15 minutes SMS door entry alarm
hi guys this is my first instructable i hope you'll enjoy it !!
Got sick of the high prices of Home Security systems ??
have old mobile sets don't know what to do with ?
build a cheap alarm system that will notify you on your mobile by SMS.
ready ??
grab the tools !
Step 1What you'll need
What you\
An old mobile phone set with supply (charger).
Cheap door magnetic alarm (can be replaced by a magnetic switch and a magnet ).
5 volts Relay.
Soldering iron.
wires and thin insulated copper wires.
micro driller.
micro screwdriver set.
clipper.
multimeter.
Scotch tape.
104 comments
1-40 of 104next »
Jan 18, 2012. 3:20 AMBIGMOMO says:
hey i am Egyptian too i am very glad that Egyptian people in instructables
May 29, 2011. 2:52 PMAyman_Alqdah says:
E4CHHHHHHHHHHHHHHHHHHH1 '.HJ 9DI GD 'DE41H9 'D'C+1 EF 1'&9 H'F' (-JC EF 'D'1/F H'F 4'! 'DDG DD'E'E HF4HA '4J ,/J/
May 24, 2011. 10:03 AMF9(/'D1-EF says:
MSA ya Mostafa keep on, and I'm sure that someday you will be a great inventor ;). Bas sa3tha mtt3allish 3alina :DD
Nov 8, 2009. 9:25 AMmiffy1297 says:
Hi Am I missing something , Once the switch is made , does this not mean that the send button is effectively on all the time. I am thinking of using the system on my old boat , to warn of water ingress , but the switch would make once only , whereas you really want a pulse to operate the phone.
any ideas.
Miffy
Nov 10, 2009. 10:58 AMmiffy1297 says:
Hi
Many thanks will rig up a circuit and try this.
Mar 14, 2011. 9:06 AMwaddellm says:
Hi Miffy,
I am wondering if you ever got this to work for your old boat. I arrived at the same instructable because I am trying to do the exact same thing to warn me if the bilge pump is running, or if the water level gets too high on my vintage boat.
Any help you can offer would be great!
thanks,
Mar 15, 2011. 1:24 PMmiffy1297 says:
Hi waddellm
Yes I have had this system working on my boat for the last two years. The only problem I had was keeping the phone battery charged . as I can leave the boat for several months over the winter, All I did was connect the bilge switch do the phone contacts , unfortunatly it was never tested as I have not had a leak.
Best wishes Andy
Dec 3, 2009. 10:00 AMmiffy1297 says:
Hi
Has anyone managed to connect wires to the light or sounder on a phone in order to switch anything on via a phone, any ideas.
Feb 14, 2011. 12:01 AMroland985 says:
Oooh, Oooh, I know. A BOMB!!!
Jan 15, 2010. 12:54 AMTheBestJohn says:
you could also arduino this to send an email to your cellphone... It would cost less than having a whole other phone's bill. As far as I know any cellphone provider gives their phone numbers email addresses.
Jan 18, 2010. 2:34 PMJamesRPatrick says:
I think a prepaid phone would be even cheaper.
Dec 3, 2009. 12:17 PMmiffy1297 says:
Thanks a lot , i had wondered whether this would work , I had tried connecting to the vibrator in the phone but this proved too tricky,
Feb 15, 2011. 4:15 PMmanutea says:
Nice instructables, I love its simplicity!
thanX 4 sharing this project
Apr 27, 2010. 5:45 PMtimotb says:
I love the High School Ingenuity. (Yes, that is a compliment.)  .  If you guys  can get together and build a simple refined device that will use the cellular system to send a SMS alarm message, like what we see here only with refinement.....let me know.....there is a market for a cheap alarm notifier..
Apr 20, 2010. 10:22 PMjules15 says:
PanadoL, where did you get those special tools to open the phone case?
Feb 19, 2010. 8:39 PMhunterbait93 says:
 instead of doing the weird stuff with the magnetic switch, just set it on the door frame and put a magnet into the door so it passes, duh
Apr 20, 2010. 10:16 PMjules15 says:
i tried that last year and the relay is much easier
Apr 5, 2010. 4:30 PMaussa says:
Nicely done, I would recommend adding the wires to number button and adding your number to a speed dial assigned to that specific button. I made a similar thing in my car. But is triggered by the car alarm system ( in case I am away and cant hear the alarm)
Feb 19, 2010. 8:44 PMhunterbait93 says:
 maybe you could make an electromagnet with a concealed switch outside the door so you can turn it on and off
Jan 24, 2010. 1:17 PMTechXhacker says:
You do not need the alarm to send the message. Simply remove the small green, which is the magnetic sensor, and paste on the side of the phone. The magnet will be laid at the door, and when someone opens the OK button is pressed. Only has the disadvantage that when placed in the door can only be disabled after entering the house, which creates a cost (it's expensive!). A tip: put a switch activated by key on the outside wall, using an existing passage (a conduit, for example).
Or, you can think big, and put a remote control, connected to a relay! (Not so expensive, and it is sold ready for use). But the idea was good. I had thought about it but thought it would not work.
Oct 20, 2009. 8:39 AMsulphurissweet says:
can u help me with where to connect the wires. that is which wire to which terminal of the relay
Sep 11, 2009. 2:05 PMibuildcrap says:
This is cool but it will only work ONCE after the door is opened which will make it send the message. A much more reliable method would be to connect an arduino to the magnetic switch and make a simple program to send the computer a number if the switch is opened over the usb cable. On the computer side you could pick from a bunch of different languages like vb.net, arduino ect... But what you would do is write a program on the computer that listens on the usb (serial port) and if it reads the specific number from the arduino like 2 for door open then it would send an email BUT when you send the email it would be yourphonenumber@yourcarriersemail2text for example 1234563456@vtext.com <-- this will send a text message to that number if it is a VERIZON wireless phone most carriers have this email to text service, just look up your exact carriers.
Oct 7, 2009. 8:24 PMlightsyoung says:
can you plz. give us a complete procedure  on constructing the same project especially on connecting the wire into the send button? we are looking forward to ur reply the soonest. thank you.
Oct 3, 2009. 4:36 AMwjames says:
this is my 5v relay so if my alarm is normally open/close in which pin will i connect my wires?..and which pin will i use so that the relay will have power??:)
Oct 3, 2009. 12:18 AMwjames says:
is this the logic diagram?
Oct 1, 2009. 1:00 AMknightz says:
we dont have common terminal.....is it ok????
Sep 14, 2009. 12:03 AMLittleHairyApe says:
Maybe I'm missing something. How do you set the alarm? If you set up the phone as described and open the door to go to work, that will trigger the alarm, right? Then aren't you screwed? Since the alarm is a one-shot deal, then you're done right? No more alarm...Puzzled.
Sep 27, 2009. 4:01 AMagis68 says:
why not use the relays contacts connected to a 555 reset timer circuit, so now you can adjust the reaction period and the durance of the alarm signal
Sep 14, 2009. 8:39 AMLittleHairyApe says:
Ok, thanks for your time. Cheers.
Sep 25, 2009. 10:21 AMscoobbrandon says:
i have a suggestion have a speed diel to your phone and hook a loud speaker to the phone in the alarm so when they open the door it calls your phone ant you can talk over the loud speaker
Sep 17, 2009. 1:54 AMwjames says:
how will you know if the magnetic switch is NC or NO using an analogue multimeter??
Sep 12, 2009. 3:11 PMstevescam001 says:
This idea is BOSS!
Sep 11, 2009. 7:50 PMx133tx0n3x says:
How about the you set it up to dial "your phone number" and just don't press send, then, on your mobile phone, make a new contact with the number of the old phone as "Door #1" and so on. Then when the door is open, it dials your phone number and you can hear whats going on. Wow I did a bod job of explaining that. Hope you understand
1-40 of 104next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:PanadoL
My name is Mostafa I live in Cairo, Egypt and I'm Egyptian, I'm an Engineering Student, Department of Energy and renewable Energy at ASU university, Cairo I'm interested in Technology and DIY proje...
more »
