Got sick of the high prices of Home Security systems ??
have old mobile sets don't know what to do with ?
build a cheap alarm system that will notify you on your mobile by SMS.
ready ??
grab the tools !
Remove these ads by
Signing UpStep 1What you'll need
Cheap door magnetic alarm (can be replaced by a magnetic switch and a magnet ).
5 volts Relay.
Soldering iron.
wires and thin insulated copper wires.
micro driller.
micro screwdriver set.
clipper.
multimeter.
Scotch tape.
any ideas.
Miffy
No once the message is sent "in most mobiles " it wont be sent again
you have to "re-trigger" the switch to send the SMS again,
for your application you can also make a very simple digital circuit to send one pulse and stops working,on this way you wont need to "re-trigger" the system to make it work again.
cheers
Many thanks will rig up a circuit and try this.
I am wondering if you ever got this to work for your old boat. I arrived at the same instructable because I am trying to do the exact same thing to warn me if the bilge pump is running, or if the water level gets too high on my vintage boat.
Any help you can offer would be great!
thanks,
Yes I have had this system working on my boat for the last two years. The only problem I had was keeping the phone battery charged . as I can leave the boat for several months over the winter, All I did was connect the bilge switch do the phone contacts , unfortunatly it was never tested as I have not had a leak.
Best wishes Andy
Has anyone managed to connect wires to the light or sounder on a phone in order to switch anything on via a phone, any ideas.
and put them in a sealed box, when the phone receives a call its display will emit light, this light will operate the circuit. VERY SIMPLE
another way which I've tried but it's more complicated , is by using DTMF receiver circuit through phone's headset and controlling 10 relays through the caller's phone keypad.
for sharing any ideas or help with related projects, please contact me on my e-mail : bxon@hotmail.com
thanX 4 sharing this project
Or, you can think big, and put a remote control, connected to a relay! (Not so expensive, and it is sold ready for use). But the idea was good. I had thought about it but thought it would not work.
