3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
15 minutes SMS door entry alarm
Step 2Let's get to work
Let\
here is the whole thing....you write the text message " for example : the main door was opened " then you put your mobile number then you...don't press the sending button.... you'll make the burglar do it !
you just want the magnetic switch to work as the sending button.
but unfortunately most of the alarms on the market contains an NO "normally-open" magnetic switch
so when the magnetic field applies "that means the door is closed ", the switch closes. and that means also that when the door is opened the magnetic field vanishes and the switch is opened..
we need the opposite of that we need the switch is closed when the door is opened and vise versa
what will we do ?? you can just seek a SPDT "Single Pole Double Throw" magnetic switch from components shops this should solve the problem of the whole alarm, but this was hard to find so i used a relay powered by the mobile charger to do the job..
The other problem is that some mobile sets closes the keypad automatically or switch to standby mode after a period of time "in order to save energy" but most of old ones doesn't... you just have to go to settings and turn of the automatic keypad lock.
if your mobile does closes the keypad automatically or switches to stand buy mode then you'll have to build a small 555 timer circuit that will trigger any unvital key on the keypad like the volume control " every 3 sec for example " to keep it on the send message mode.. of course the mobile should be powered from the charger all the time.
13 comments
Nov 8, 2009. 9:25 AMmiffy1297 says:
Hi Am I missing something , Once the switch is made , does this not mean that the send button is effectively on all the time. I am thinking of using the system on my old boat , to warn of water ingress , but the switch would make once only , whereas you really want a pulse to operate the phone.
any ideas.
Miffy
Nov 10, 2009. 10:58 AMmiffy1297 says:
Hi
Many thanks will rig up a circuit and try this.
Mar 14, 2011. 9:06 AMwaddellm says:
Hi Miffy,
I am wondering if you ever got this to work for your old boat. I arrived at the same instructable because I am trying to do the exact same thing to warn me if the bilge pump is running, or if the water level gets too high on my vintage boat.
Any help you can offer would be great!
thanks,
Mar 15, 2011. 1:24 PMmiffy1297 says:
Hi waddellm
Yes I have had this system working on my boat for the last two years. The only problem I had was keeping the phone battery charged . as I can leave the boat for several months over the winter, All I did was connect the bilge switch do the phone contacts , unfortunatly it was never tested as I have not had a leak.
Best wishes Andy
Feb 19, 2010. 8:39 PMhunterbait93 says:
 instead of doing the weird stuff with the magnetic switch, just set it on the door frame and put a magnet into the door so it passes, duh
Apr 20, 2010. 10:16 PMjules15 says:
i tried that last year and the relay is much easier
Oct 3, 2009. 12:18 AMwjames says:
is this the logic diagram?
Sep 11, 2009. 4:58 PMsting_hbh says:
egypt #1
Sep 9, 2009. 11:48 PMochoa10 says:
(if I write something wrong excuse me; I´m Latin) macobt make me have an idea: You can even add a switch to every pin number of speed dial from 1 to 9 to monitor every door or windows of your house! Regards to all.
Sep 10, 2009. 12:20 PMochoa10 says:
Hi, Panadol! I don't know why?, I can't assign the pin number 1 of the speed redial; But from 2 to 9, I did it! to the same telephone number; I can imagine that i can assign different SMS to the same telephone number!
Sep 11, 2009. 12:13 PMdirtbiketrailsrider says:
If you have multiple phones on each door and window and you have them call, you can set your phone (the receiver) to have a different ring tone for each window/door. Nice Instructable.
Sep 5, 2009. 6:10 AMmacobt says:
Good,instead mesage you can make a call to number from speed dial number on the keyboard,same schematic just conect the wires to pin numbers from 1 to 9,and when a door is open one of speed dials are presed and call too desire number,even you can answer too this call and listen what is hapening. regards macobt
Sep 8, 2009. 1:19 PMbatman96 says:
All you have to do is call the phone as soon as you receive the "robber" txt msg. put the ringer on silent, and turn on auto answer. So you can listen in if you want to.
Sep 11, 2009. 8:29 AMmacobt says:
why to do that,when the alarm is turn in on when is conected one of speed numbers and auto conecting to disere number,and you can answer the call and listen,another suggestion is to conect speaker phone to alarm to be louder when you speak,too scare the intruder.
Sep 11, 2009. 6:05 AMversanil says:
You could connect a loudpeaker and talk to the robber. Suggest alternative sources of income XD
Sep 11, 2009. 3:26 PMmacobt says:
MY ALARM SYSTEM HERE IS PICTURE.
Feb 6, 2010. 8:16 AMjiyoonasan says:
 sir please help me with my thesis.. i am willing to learn that thing its because it will be useful for our thesis authomated door access i hope u can help us.. sir, it case i am requesting for some video or screen shots on how to do that.. tnx a lot.. hoping for your reply..tnx.
Feb 6, 2010. 10:48 AMmacobt says:
first tell me whether you have knowledge of electronics???
Sep 11, 2009. 4:29 PMmacobt says:
Here is link to schematic very simple>
http://english.cxem.net/guard/guard42.php
Regards Panadol
Sep 5, 2009. 4:18 PMfkuk says:
just add a switch in the line and add that switch out side the door and one switch inside the room in a hidden location
Sep 5, 2009. 10:23 PMi make shooting things says:
Perhaps a hidden magnetic relay thingy; just hold a magnet to a spot on the door with a magnetic switch hidden on other side. But thats pushing it, probably better to just keep things simple.
Sep 6, 2009. 9:58 AMmacobt says:
sometimes simple things are better,but when you build a alarm for your house then we need something more intelligent,like this cell call when someone want to get in the house and you are alerted by call of your alarm and when you answer to call you may listen what is hapening.regards to all.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:PanadoL
My name is Mostafa I live in Cairo, Egypt and I'm Egyptian, I'm an Engineering Student, Department of Energy and renewable Energy at ASU university, Cairo I'm interested in Technology and DIY proje...
more »
