3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
15 minutes SMS door entry alarm
Step 6Test it now ....
test it now ....
After checking the wiring and preparing the text your alarm system should be ready
just mount the the magnet on the door and the set on the frame , plug the charger into mains , switch on the mobile open the message and put the mobile number...
of course it's better to mount it in casing or something ...
now it's ready !
waiting for your comments and suggestions : )
13 comments
May 24, 2011. 10:03 AMF9(/'D1-EF says:
MSA ya Mostafa keep on, and I'm sure that someday you will be a great inventor ;). Bas sa3tha mtt3allish 3alina :DD
Apr 20, 2010. 10:22 PMjules15 says:
PanadoL, where did you get those special tools to open the phone case?
Apr 5, 2010. 4:30 PMaussa says:
Nicely done, I would recommend adding the wires to number button and adding your number to a speed dial assigned to that specific button. I made a similar thing in my car. But is triggered by the car alarm system ( in case I am away and cant hear the alarm)
Feb 19, 2010. 8:44 PMhunterbait93 says:
 maybe you could make an electromagnet with a concealed switch outside the door so you can turn it on and off
Jan 24, 2010. 1:17 PMTechXhacker says:
You do not need the alarm to send the message. Simply remove the small green, which is the magnetic sensor, and paste on the side of the phone. The magnet will be laid at the door, and when someone opens the OK button is pressed. Only has the disadvantage that when placed in the door can only be disabled after entering the house, which creates a cost (it's expensive!). A tip: put a switch activated by key on the outside wall, using an existing passage (a conduit, for example).
Or, you can think big, and put a remote control, connected to a relay! (Not so expensive, and it is sold ready for use). But the idea was good. I had thought about it but thought it would not work.
Sep 14, 2009. 12:03 AMLittleHairyApe says:
Maybe I'm missing something. How do you set the alarm? If you set up the phone as described and open the door to go to work, that will trigger the alarm, right? Then aren't you screwed? Since the alarm is a one-shot deal, then you're done right? No more alarm...Puzzled.
Sep 27, 2009. 4:01 AMagis68 says:
why not use the relays contacts connected to a 555 reset timer circuit, so now you can adjust the reaction period and the durance of the alarm signal
Sep 14, 2009. 8:39 AMLittleHairyApe says:
Ok, thanks for your time. Cheers.
Sep 11, 2009. 1:02 PMFodaro says:
Isn't there some sort of chipset you can buy to send the text message? I'm just thinking that having to hack the phone and have it on all the time might be unnecessary.
Sep 11, 2009. 9:49 AMSpiderSpartan says:
Doesn't this require that phone to have service too?
Sep 11, 2009. 10:57 AMnot__you says:
Yeah, but if you have an old prepaid phone an hour of talk time should last you the life of the alarm unless your house gets broken into on a regular basis. :)
Sep 10, 2009. 4:42 AMbkf11 says:
Nice, I like the simplicity and low cost. Some phones can ring a number in the phone book when you hold down a number key. That would be an alternative to sending a text and it could reset itself (when you pick up and hang up the phone call) and you can listen to what is happening too if you want. In that case even better to have a hands free kit plugged in for better microphone sensitivity. I did a similar thing to an ancient Alcatel One Touch Easy with soldering wires to the keypad but used a picaxe microcontroller to "push" several buttons to turn the phone on, dial a number via the 'hold the key down' method and then hang up after a few seconds and turn the phone off. This could notify me of an event via the ring and caller ID.
Sep 5, 2009. 6:41 AMacer5050 says:
Good idea, but it requires a manual reset every time its set off. and how do you disable it?
Sep 3, 2009. 3:53 PMSe7s says:
Good Job
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:PanadoL
My name is Mostafa I live in Cairo, Egypt and I'm Egyptian, I'm an Engineering Student, Department of Energy and renewable Energy at ASU university, Cairo I'm interested in Technology and DIY proje...
more »
