$1.50 Heavy Duty Extension Cord by iectyx3c
A heavy duty 6 foot 120 Volt extension cord is expensive, so make your own for about $1.50 each.
Remove the heavy duty cord from an old appliance you are recycling.
Pass the end through one of the holes in a $0.39 blue single gang workbox.
Then tie a knot for strain relief.
Strip the ends and attach to a $0.59 15 Amp outlet - green wire to green screw, white to silver screw, black to gold.
Screw the outlet in place and add a two outlet nylon "unbreakable" cover plate for $0.47 and you are done.
Plug and play. Remember extension cords are for temporary use only in dry areas.
iApple guy says: Oct 23, 2012. 7:47 PM
Use a metal box, a metal cover, and a hospital grade outlet and plug thing for added durability.
webman3802 says: Oct 11, 2012. 6:15 AM
With some additional wiring, you could put it in a double gang box and add a switch to control the outlet. Using a dimmer switch also opens up possibilities to control lighting, motor speed, etc.
iectyx3c (author) says: Oct 11, 2012. 6:38 AM
Using a double gang box is an excellent suggestion and allows for all kinds of add-ons. Timer could be used to control Halloween lighting or other decorations.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
