3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$15.00 pneumatic PVC sniper
This is a pneumatic PVC sniper I made for $15.00. It can shoot over 92.5 meters (300 feet) with some accuracy and 9 to 15 meters (30-50 feet) accurately. It holds 100 psi but 60 psi is enough.
Step 1PARTS
PARTS
Here is a list of all the parts.
1:(2) male 1/2 in threaded-slip adapter
2:(1) 5 ft of 1/2 in PVC pipe
3:(1) 1 ft of 2 in 280 psi PVC pipe
4:(1) 2 in to 1/2 in PVC reducer bushing
5:(1) 2 in PVC coupling
6:(1) thread seal tape
7:(1) 1/2 in threaded metal gas ball valve
8:(1) 2 in PVC end cap
*9:(1) Schrader tier valve
*10:(x) baby carrots
Tools: Drill with 1/2 in bit, Saw, Supper-glue, PVC primer and cement.
  • tier valve can be gotten for free at most car tier dealers. Everything else can be found at Lowes or any other hardware store in the plumbing section. you can use as many baby carrots as you want for ammo.
5 comments
Jan 20, 2012. 1:24 AMde0509 says:
actually i dont think you should call it "sniper". it has no scope, not even sights. and then, the gun would wobble when triggering the ball valve, which makes it less accurate.
Nov 14, 2009. 2:41 PMColonel88 says:
Isn't the tire valve going to open fast enough? Because i always thought that the best thing to use is a sprinkler valve
Oct 6, 2009. 5:03 AMflashanimator says:
Nice Job 5/5
Oct 3, 2009. 7:55 PMlemminggenocide says:
goo job 5*
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MXR789
