16F877a & Bluetooth
Published
Introduction: 16F877a & Bluetooth
This is my first play with the HC-05 Bluetooth device (and my first instructable !)
I programmed the PIC to receive and send data @ 9600 baud as this was the default settings of the HC-05.
Basically I connect to the bluetooth device and send data from my Android phone.
Sent text gets displayed on the LCD panel. Sending '#' then numbers 1 to 8 operates the associated relay.
When the relay is activated, the PIC sends either the number of the intended relay activated (1 to 8) or a letter, A to H (A = relay 1, B= relay 2 etc.)
This returned value is used to change the colour of the text on the button from red to green or green to red depending on the state of the relay.
Because there is no 'handshaking' I send each character with a 250ms delay to avoid overrun.
The PIC programme was written with the aid of Oshonsoft simulator (invaluable and inexpensive software) and the Android App was written using MIT App Inventor 2 - a completely different way of coding, but an excellent piece of software - and it's FREE !
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    12 Comments
    Here is the PIC code. Its a tad messy as its based around an LCD test prog from China.
    Not too much in the way of comments either :-(
    ;Control LCD & Relays using Bluetooth . Servo code for future - code untested.
    ;Based on LCD test code - some code is not used!
    #INCLUDE<c:\P16F877a.INC>
    __CONFIG _DEBUG_OFF&_CP_ALL&_WRT_HALF&_CPD_ON&_LVP_OFF&_BODEN_OFF&_PWRTE_ON&_WDT_OFF&_HS_OSC
    ;THE configure of MCU,watchdog OFF,electrify delay OPEN,power down check OFF,
    ;LOW power programme OFF,encrypt,4M crystal HS surge.
    Z EQU 2 ;define Z status's address
    RP0 EQU 5 ;define RP0's address
    ;#DEFINE RS PORTC,0
    ;#DEFINE RW PORTC,1
    ;#DEFINE E PORTC,4
    #DEFINE RS PORTA,1
    #DEFINE RW PORTA,2
    #DEFINE E PORTA,3
    ;RS EQU 1 ;
    ;RW EQU 2 ;
    ;E EQU 3 ;
    COUNT2 EQU 27H ;define count reg address
    TMP1 EQU 28H ;define temp count reg.
    COUNT3 EQU 34H ;define count reg address
    TMP3 EQU 35H ;define temp count reg.
    VAL_US EQU .249 ;short delay parameter
    VAL_MS EQU .200 ;long delay parameter
    COUNT EQU 25H
    COUNT_MS EQU 26H
    ORG 00H
    NOP
    NOP
    NOP
    GOTO MAIN
    ORG 04H ;interrupt entrance address
    BTFSS PIR1,RCIF ;judge if COMM receive interrupt
    GOTO nextint ;no, jump to interrupt end program
    MOVF RCREG,0 ;read data of receive register
    goto after
    nextint
    btfss INTCON,2
    goto EXIT
    call serv
    goto EXIT
    after
    movwf 2Ah;temp store for rx buffer
    isittilde ; ~ stop servo control
    movf 02Ah,0
    XORLW 07eH;~
    BTFSS STATUS,Z
    goto isitcaret
    clrf 02bh ; clr the last ctrl
    BCF INTCON,5h ; timer0 int DISable
    goto EXIT
    isitcaret ; will be used control servo motor
    movf 02Ah,0
    XORLW 05eH;^
    BTFSS STATUS,Z
    goto testcarat ;isithash
    incf 030h
    BSF INTCON,5h ; timer0 int enable
    movf 02ah,0 ; tmp store of last control character
    movwf 02bh
    movlw 02h
    movwf 02eh
    goto EXIT
    testcarat
    movf 02bh,0 ;was prec cont char ^
    XORLW 05eh
    BTFSS STATUS,Z
    goto isithash ;clrit ; was clrit
    movf 02ah,0 ;delay value for servo delay
    movwf 03fh
    goto EXIT
    isithash
    movf 02Ah,0
    XORLW 023H;#
    BTFSS STATUS,Z
    goto testhash
    movf 02ah,0
    movwf 02bh
    movlw 02h
    movwf 02eh
    ;call Line2
    goto EXIT
    testhash
    D3 movf PORTB,0
    movwf 03ah ; temp copy of portb
    ;set bit on port D if prevoius char was a #
    movf 02bh,0
    XORLW 023h
    BTFSS STATUS,Z
    goto clrit
    movf 02Ah,0
    ANDLW 0fh
    MOVwf 02ch
    movf 02ch,1
    movlw 01h
    movwf 02dh
    dexRLF 02dh, 1
    DECFSZ 02ch, 1
    goto dex
    RRF 02dh, 1
    movf 02dh,0
    XORWF PORTB,1 ; update relays
    ;;===================transmit relay info =======================
    movf 02Ah,0
    ANDLW 0fh
    movwf 03dh
    b0
    movf 03dh,0
    XORLW 01h
    BTFSS STATUS,Z
    goto b1
    movf 02Ah,0
    btfss PORTB,0
    ADDLW 10h
    call txit
    b1
    movf 03dh,0
    XORLW 02h
    BTFSS STATUS,Z
    goto b2
    movf 02Ah,0
    btfss PORTB,1
    ADDLW 10h
    call txit
    b2
    movf 03dh,0
    XORLW 03h
    BTFSS STATUS,Z
    goto b3
    movf 02Ah,0
    btfss PORTB,2
    ADDLW 10h
    call txit
    b3
    movf 03dh,0
    XORLW 04h
    BTFSS STATUS,Z
    goto b4
    movf 02Ah,0
    btfss PORTB,3
    ADDLW 10h
    call txit
    b4
    movf 03dh,0
    XORLW 05h
    BTFSS STATUS,Z
    goto b5
    movf 02Ah,0
    btfss PORTB,4
    ADDLW 10h
    call txit
    b5
    movf 03dh,0
    XORLW 06h
    BTFSS STATUS,Z
    goto b6
    movf 02Ah,0
    btfss PORTB,5
    ADDLW 10h
    call txit
    b6
    movf 03dh,0
    XORLW 07h
    BTFSS STATUS,Z
    goto b7
    movf 02Ah,0
    btfss PORTB,6
    ADDLW 10h
    call txit
    b7
    movf 03dh,0
    XORLW 08h
    BTFSS STATUS,Z
    goto b8
    movf 02Ah,0
    btfss PORTB,7
    ADDLW 10h
    call txit
    b8
    goto EXIT
    clrit
    movfw 02Ah
    XORLW 01H;
    BTFSS STATUS,Z
    goto Homeit
    MOVLW 01H
    MOVWF PORTD ;clr screen
    CALL ENABLE
    CALL DELAY ;delay for lcd is slower than mcu.
    CALL DELAY
    CALL DELAY
    clrf 02fh ; clr char counter
    goto EXIT
    Homeit
    movfw 02Ah
    XORLW 02H;
    BTFSS STATUS,Z
    goto DISP
    MOVLW 02H
    MOVWF PORTD ;home screen
    CALL ENABLE
    CALL DELAY
    CALL DELAY
    goto EXIT
    DISP
    ;it was not FF or FE so we can Display the data
    movfw 02Ah
    MOVWF PORTD
    CALL WRITE3
    ;MOVWF TXREG ;keep in send register and send
    EXIT
    RETFIE
    infobak
    ADDWF PCL,1 ;address offset add the current pc.
    RETLW 20h
    RETLW 41H ;A
    RETLW 42H ;B
    RETLW 43H ;C
    RETLW 44H ;D
    RETLW 45H ;E
    RETLW 46H ;F
    RETLW 47H ;G
    RETLW 48h ;H
    RETLW 00H
    TABLE ;display version
    RETLW 20H ;space
    RETLW 56H ;V
    RETLW 65H ;e
    RETLW 72H ;r
    RETLW 73H ;s
    RETLW 69H ;i
    RETLW 6fH ;o
    RETLW 6eH ;n
    RETLW 20H ;space
    RETLW 33H ;3
    RETLW 2eH ;.
    RETLW 31H ;1
    RETLW 30H ;0
    RETLW 30H ;0
    RETLW 30H ;0
    RETLW 61H ;0
    RETLW 00H
    TABLE1 ;display terry reynolds
    RETLW 20H ;space
    RETLW 54H ;T
    RETLW 65H ;e
    RETLW 72H ;r
    RETLW 72H ;r
    RETLW 79H ;y
    RETLW 20H ;space
    RETLW 52H ;R
    RETLW 65H ;e
    RETLW 79H ;y
    RETLW 6eH ;n
    RETLW 6fH ;o
    RETLW 6cH ;l
    RETLW 64H ;d
    RETLW 73H ;s
    RETLW 00H
    TABLE3
    RETLW 20H ;space
    RETLW 54H ;T
    RETLW 65H ;e
    RETLW 72H ;r
    RETLW 72H ;r
    RETLW 79H ;y
    RETLW 00H
    MAIN
    USART
    BANKSEL TRISC ;select BANK1
    MOVLW 0FFH ;set RA5 OUTPUT,the other bits INPUT
    ;MOVWF TRISB
    BSF TRISC,7 ;disconnect RC and USART TX
    BSF TRISC,6 ;disconnect RC and USART RX
    BcF TRISC,0
    BcF TRISC,1
    BcF TRISC,2 ; bits 0,1,2 & 3 of portc out put to control relay
    BcF TRISC,3 ;
    BcF TRISC,4
    MOVLW 0CH ;load band rate=9600 0c=19200 brgh high
    MOVWF SPBRG
    MOVLW 24H ;enable USART,set band rate is high
    MOVWF TXSTA
    ;movlw 090h
    ;movwf RCSTA
    BSF PIE1,RCIE ;enable receive interrupt
    MOVLW 00h
    MOVWF TRISB
    ;BANKSEL TRISD
    MOVLW 00h
    MOVWF TRISD
    CLRF STATUS ;select BANK0
    movlw 090h ;090h =cont rx
    movwf RCSTA
    movlw 0ffh ; set all portB o/p high as relay is active low
    movwf PORTB
    CLRF PORTA
    BSF STATUS, RP0
    MOVLW 0x06
    MOVWF ADCON1
    MOVLW 0f0h
    MOVWF TRISA
    movlw 06h
    movwf OPTION_REG
    movlw 0ffh
    movwf 03fh
    MOVLW 0f0h ;; timer0
    movwf TMR0
    CALL DELAY
    MOVLW 90H
    MOVWF RCSTA ;enable USART continue receive
    BSF INTCON,GIE ;enable general interrupt
    BSF INTCON,PEIE ;enable outside interrupt
    ;BSF INTCON,5h ; timer0 int enable
    ; start up value for servo
    movlw 0xC7 ; value from user after ^ : 1ms centre = C7 1.5ms right = B7 2.0ms left =8f
    movwf 03fh
    ;the following 16 instructions to set lcd display mode.
    MOVLW 30H
    MOVWF PORTD
    CALL ENABLE ;write command.
    MOVLW 30H
    MOVWF PORTD
    MOVLW 30H
    MOVWF PORTD
    MOVLW 01H
    MOVLW 38H
    MOVWF PORTD ;8 bits 2 lines 5*7 mode.
    CALL ENABLE
    MOVLW 0EH ;display on,cursor on,blink on.
    MOVWF PORTD
    CALL ENABLE
    MOVLW 06H ;character not move,cursor rotate right.
    MOVWF PORTD
    CALL ENABLE
    MOVLW 080H;80 = top line c0 = bottom line
    MOVWF PORTD ;the 1st line address.
    CALL ENABLE
    ;MOVLW 54H
    ;;MOVWF PORTD
    CALL WRITE1 ;.
    USART_1
    CALL DELAY_MS ;call two delay program
    ; CALL DELAY_MS
    ;CALL DELAY_MS
    btfss PORTE,0
    GOTO num2
    movlw 08fh
    movwf 03fh
    num2 btfss PORTE,1
    GOTO num3
    movlw 0b7fh
    movwf 03fh
    num3 btfss PORTE,1
    GOTO errbit
    movlw 0c7fh
    movwf 03fh
    errbit
    btfss RCSTA,2
    goto erbit2
    bsf PORTB,7
    erbit2
    btfss RCSTA,1
    goto USART_1
    bsf PORTB,6
    GOTO USART_1 ;
    ;***** set to line 2.
    Line2
    ;CALL DELAY ;delay for lcd is slower than mcu.
    MOVLW 0C0H;80 = top line c0 = bottom line
    CALL ENABLE
    Return
    ;***** set to line 1 .
    Line1
    CALL ENABLE
    Return
    ;************************200ms delay program******************
    DELAY_MS
    MOVLW VAL_MS
    MOVWF COUNT_MS
    LOOP_MS
    CALL DELAY_US
    DECFSZ COUNT_MS,1
    GOTO LOOP_MS
    RETURN
    ;************************100us delay program**************
    DELAY_US
    MOVLW VAL_US
    MOVWF COUNT
    LOOP_US
    NOP
    DECFSZ COUNT,1
    GOTO LOOP_US
    RETURN
    DELAY_S
    MOVLW 0FFH
    MOVWF 50H
    CALL DELAY_MS
    DECFSZ 50H,1
    GOTO $-2
    RETURN
    ;******************send data to lcd.************
    WRITE3
    BSF RS
    MOVWF PORTD
    BCF RW
    BCF E
    CALL DELAY
    BSF E
    incf 02fh ;check for end of line1 - character counter 02fh
    movlw 010h
    xorwf 02fh,0
    char16
    BTFSS STATUS,Z
    goto char32
    MOVLW 0c0H;80 = top line c0 = bottom line
    CALL ENABLE
    call DELAY
    char32 ;check for end of line2
    movlw 020h
    xorwf 02fh,0
    BTFSS STATUS,Z
    goto here
    MOVLW 01H;80 = top line c0 = bottom line -01 =cls 02= home
    CALL ENABLE
    call DELAY
    clrf 02fh; reset character counter
    here;incf 02fh ;check for end of line1 - character counter 02fh
    RETURN
    WRITE4
    BSF RS
    MOVWF PORTD
    BCF RW
    BCF E
    CALL DELAY
    CALL DELAY
    ;CALL DELAY
    BSF E
    Return
    ;****************send command to lcd.**************
    ENABLE
    BCF RS ;
    BCF RW
    BCF E
    CALL DELAY
    CALL DELAY
    ;CALL DELAY
    BSF E
    RETURN
    ;*********************delay subroutine******************
    DELAY ;subroutine name and also is the entry.
    MOVLW 0FFH ;
    MOVWF 20H ;send external loop count 0ffh to 20h
    LP0
    MOVLW 01H ;
    MOVWF 21H ;send internal loop count 0ffh to 21h
    LP1
    DECFSZ 21H,1 ;decrease 21h,if 0,then jump
    GOTO LP1 ;continue loop at LP1
    DECFSZ 20H,1 ;decrease 20h,if 0,then jump
    GOTO LP0 ;continue loop at LP0
    RETURN ;
    Transwt bsf STATUS,RP0; RAM Page 1
    WtHere btfss TXSTA,TRMT ; (1) transmission is complete if hi
    goto WtHere
    bcf STATUS,RP0 ; RAM Page 0
    return
    ;****************** send the 1st data program***************
    WRITE1
    CLRF COUNT3 ;clear offset
    WRITE_A
    MOVFW COUNT3
    CALL TABLE ;search to display www.pic16.com
    MOVWF TMP3 ;
    INCF COUNT3,1 ;offset added
    MOVFW TMP3
    XORLW 00H ;check if finished.(the last byte is 00h.)
    BTFSC STATUS,Z
    GOTO $+4 ;all display finished.
    MOVFW TMP3
    CALL WRITE3 ;no, send to LCD
    GOTO WRITE_A ;
    call WRITE2
    RETURN ;
    ;****************** send the 2nd data program*********
    WRITE2
    WRITE_2A
    MOVFW COUNT3
    CALL TABLE1 ;search to display www.pic16.com
    MOVWF TMP3 ;
    MOVFW TMP3
    BTFSC STATUS,Z
    MOVFW TMP3
    GOTO WRITE_2A ;
    ;incf 02fh
    RETURN ;
    serv
    incf 041h
    bcf INTCON,2
    bsf PORTC,1
    call servtime
    bcf PORTC,1
    movlw 0fah
    movwf 03fh
    retfie
    servtime
    ;movlw 0xB7 ; value from user after ^ : 1ms centre = C7 1.5ms right = B7 2.0ms left =8f
    movwf 03fh
    movlw 0x0C
    movwf 040h
    Delay_0
    decfsz 03fh, f
    goto $+2
    decfsz 040h, f
    goto Delay_0
    return
    txit movwf TXREG ; echo data back to sender
    call Transwt; wait until finished sending
    clrf 02bh
    decfsz 02eh,1
    return
    END
    Sir, even if you gave the original file of this project . . Its still unable for me to run that source code . . I didnt even know which part that i need to erase . . I just wanna play around the code with protues software .however i was unable to assemble the file into hex file . . Sorry sir im disturbing you too much
    Hi
    The protues software looks interesting !!
    It has been a while since I programmed the PIC chips.
    The code has to be compiled using Microchip MPASM and then uploaded to the PIC !
    Programming PIC chips using assembly code can be challenging and at times, frustrating.
    I changed to Arduino mainly due to the amount of free knowledge and examples there are on the Internet!
    Programming, debugging and testing are so much easier using the Arduino - and they are so cheap too!
    I am not too sure what your goals are, what are you trying to achieve please? Is it for learning or a particular project?
    kind regards
    Terry
    Hi samsungite . . Can u send me the actual source code asm of pic simulator ide . . Tq in advance . . Plss . . Kekekep93@gmail.com
    I will try and add the original file to the project
    Terry :-)
    Thank you sir . . After this project working . . I wanted to play with arduino soon . . Huhu
    Hi
    If you are programming pic chips, this software is invaluable !!
    Terry
    http://www.oshonsoft.com/pic.html
    Sir ,currently im using this oshon pic simulator ide and ive tried to assemble and load above coding, unfortunately theres a lot off error . . T_T
    Hi
    Thank you & I'm really sorry for the dreadfully long delay in responding.
    It was more a proof of concept! I've done a few projects with a PIC but I have fallen in love with the Arduino!!
    My first Arduino project also uses Bluetooth, so the knowledge gained from using a PIC was invaluable.
    I will post the project over the Christmas period, its a time lapse trigger for a Sony camera using IR !
    I'm also working on my Internet of Things, first of these will be a milk monitor !!
    Terry
    nice,
    can you please share the code??
    Hi there,
    Excellent project there. Would you be willing to share the coding?
    Thank you.
    Cool first Instructable! It looks like you've mostly heard crickets to this point, so consider using the video as a supplement to a step by step project rather than the sole piece of media that you share. Was this a proof of concept or do you have grander designs for this project?
