Introduction: 180 Eachine: Part 2 - Motors and Frame
Picture of 180 Eachine: Part 2 - Motors and Frame
This Part continues to build a modified 180 Eachine Falcon.
Step 1: Assembly of Motors and ESC's
Picture of Assembly of Motors and ESC's
Attach the motors to the esc's
Step 2: Solder Direct to Esc's
Picture of Solder Direct to Esc's
I remove the shrink wrap around the esc and attach th motor directly.
Step 3: Shorten the Motor Conection
Picture of Shorten the Motor Conection
I shorten the motor wires and re-soldered them to the board.( always keep in mind you might have to change the wires during esc caliberation for rotation purposes) Re-shrinkwrap the esc.
Step 4: Motor Slant Mount
Picture of Motor Slant Mount
You can use this forward slant mount. It helps keep the drone from leaning to far forward for forward flight. Not good for hovering. Use motor screws to mount to slant mount. use flat head screws to mount slant mount to frame.
Step 5: First Motor Done
Picture of First Motor Done
Now repeat and finish the other three.
Step 6: Last Update July 08, 2016
Picture of Last Update July 08, 2016
Now move onto Part 3
If you have comments please offer it. I'm learning as you are learning.
Thank you for your patience.
Bstrong5001 (author)2017-02-22
I like the forward response of the tilt. When I take off I go straight anyways
Smaht.. That's Smaht.. I hid mine under the gap between the pdb and the bottom of the carbon fiber frame
About This Instructable
2,161views
4favorites
License:
More by jhudson20:Part 3: 180 Eachine Falcon PDBoard continuation 180 Eachine: Part 2 - Motors and Frame180 Eachine Falcon: Part 1- PDBoard
Add instructable to:
