18650 Lithium Ion Battery Capacity Tester
Published
Introduction: 18650 Lithium Ion Battery Capacity Tester
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
I had bought few 9800 and few 4200 mAh lithium ion batteries from Aliexpress last year.
They were quite cheap... and as I researched more on them, I found that these are fake and their actual capacity may be very less.
Then I extracted Lithium ion batteries from old laptop battery. But wondered are these still at original capacity or have reduced their capacity
For a beginner DIYer it is difficult to buy expensive testers....
So, in this instructable, I will share how to make 1s lithium ion battery capacity tester
Please share your comments if you like this instructable.
Step 1: What Do We Need ?
Material
- TP4056 with protection
- USB female
- USB doctor
- USB Load
- Battery holder
- Wires
- Wooden board
Lots of batteries from different sources
Step 2: Assembly
- Using hotglue, glue battery holder and TP4056 module
- Connect battery holder to TP4056 on +B and - B
- Connect USB to +Vout and - Vout
Check if everything is connected correctly
Step 3: Test 1 : GTF 9800 MAh
I had got 4 batteries for 6 dollars. It claimed to have 9800mAH
Claimed Capacity : 9800 mAh
Actual capacity : 1000 mAh
Just about 10% of what it claimed
Step 4: Test 2 : 4200 MAh
I had got 4 batteries for 3.5 dollars. It claimed to have 4200mAH
Claimed Capacity : 4200 mAh
Actual capacity : 500 to 600 mAh
Little above 10% of claimed capacity
Step 5: Test 3 : Laptop Batteries LG Make
I extracted these from old HP laptop battery
Claimed Capacity : 3000 mAh
Actual capacity : 2300 mAh
Not bad for 5 year old batteries
Step 6: Test 4 : Laptop Batteries Set Samsung Make
Claimed Capacity : 2200 mAh
Actual capacity : 2000mAh
Not bad for 7 year old batteries
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    The range of the tester is 4V - 20V.
    How you test the full battery capacity from 4,2V to 2,5V?
    I test the tester and the voltages is very inaccurate under 4V.
    The display under 4V becomes darker.
    Not for me, it is good tool 2.6v
    my usb tester, is not rated for 20v, may be that's why, I am able to test lower voltage
    Where you buy it?
    My Keweisi tester has a range from 4V - 20V.
    All Keweisi tester i found on www.aliexpress.com has a measurement range from DC 4-20V too.
