3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
1986 Ford F-150: How to change the ball joint
Step 3OUT DAMN JOINTS, OUT!!!
Finally, removing the ball-joints!
The top ball joint wasn't too bad and I was able to get it out while everything was still in the truck.
Before I found the ball-joint tool at AutoZone I used a tool that was "similar" enough that it allowed me to cup the bottom bolt and apply enough pressure with a screw down clamp and I was able to push the top joint out of the arm.
As you can see from the picture below, the bottom bolt was a bit more stubborn and I tried everything (except the right tool and proper persuasion) to get it out. These guys were very rusted.
Even though I now had the right tool and had the arm out of the truck, no matter how much pressure I used I couldn't get the bottom joint to move. What did I have to do to get this SOB out???
BFH!
Yep, with full pressure applied to the joint, a swift HARD smack of the arm shoulder near the joint with a mini-sledge and POP!!!!! Out it came. TADA!!
While I had it out I sanded down the arm, treated the rust, primed it and painted it with some auto enamel.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:CBGjr
