1x4 Membrane Keypad W/ Arduino
Published
Introduction: 1x4 Membrane Keypad W/ Arduino
To some configuring this component may come easy, but for me- being new to tinkering with electronics, I found myself confused when trying to tinkering with this specific product. This was partly due to the fact that I couldn't find any information on how to utilize this component via Google, Arduino forums, etc. So I figure that other people might not get it, just as I did..
Product: https://www.adafruit.com/product/1332
Please keep in mind that this is my first instructable.
Step 1: BOM
Arduino (I used an UNO, but other variations would suffice)
1x4 Keypad w/ 5 Pins
5 Jumper Wires
Resistor & LED (if you prefer a visual)
Step 2: Assembly
Insert the 1x4 Keypad Header Pins into your breadboard & place 1 jumper cable directly in front of each pin of the header.
(left to right)
The first wire should be connected to a GRND Pin on your Arduino.
The 2nd, 3rd, 4th, and 5th wire should be connected to 4 Digital Pins on your Arduino. To keep it simple, I chose pins 9-12
  • Digital Pin #9, would be the #1 key on your keypad
  • Digital Pin #10, would be the #2 key on your keypad
  • Digital Pin #11, would be the #3 key on your keypad
  • Digital Pin #12, would be the #4 key on your keypad.
Verify your connections.
Step 3: Code
Paste the following into an empty Arduino Sketch & Save it. Continue to Next Step for explanations.
1x4 Keypad from Adafruit.com (Unofficial Source) Original Source: Button Referenced Tutorial on Arduino.com: http://arduino.cc/en/Tutorial/InputPullupSerial Referenced: http://arduino.cc/en/Reference/pinMode
Turns on and off specified Pin or Prints to Serial Monitor when keys are press on a 1x4 keypad from Adafruit.com
The (OLD) circuit: * LED attached from pin 13 to ground * pushbutton attached to pin 2 from +5V * pushbutton attached to pin 3 from +5V * 10K resistor attached to pin 2 from ground
The (NEW) circuit (2014):
* Whichever component you want attached to Pin 13 (e.g- LED) * 1x4 Keypad w/ primary pin attached to Ground and 1-4 keys attached to PINS 9-12 * Serial Monitor used for output (for testing, when not using anything attached to Pin 13)
* Note:
created 2005 by DojoDave modified 30 Aug 2011 by Tom Igoe modified 10 Apr 2012 by mpilchfamily modified 8 Dec 2014 by C Cunningham
/ constants won't change. They're used here to // set pin numbers: const int buttonPin[] = {9,10,11,12}; // the number of the pushbutton pins const int ledPin = 13; // the number of the LED pin
// variables will change: int buttonState = 0; // variable for reading the pushbutton status
void setup() { // initialize the LED pin as an output: pinMode(ledPin, OUTPUT); // initialize the Serial Monitor @ 9600 Serial.begin(9600); // initialize the keypad pin(s) as an input: for(int x=0; x<2; x++) { pinMode(buttonPin[x], INPUT_PULLUP); } }
void loop(){ // read the state of the keypad value: for(int x=0; x<2; x++) { //signifying the state of which the button is in by reading the appropriate pin # buttonState = digitalRead(buttonPin[x]);
// check if the pushbutton on the keypad is pressed. // if it is, the buttonState is LOW: if (buttonState == LOW && buttonPin[x] == 9) { // turn LED off: Serial.print("OFF * "); // digitalWrite(ledPin, LOW); } if (buttonState == LOW && buttonPin[x] == 10) { // turn LED off: Serial.print("ON *"); //digitalWrite(ledPin, LOW); } } }
Step 4: You're Done!
Verify & Compile, Upload, and Open your Serial Monitor. Press your buttons. I only used buttons 1 & 2 for ON/OFF Functions. Code could be expanded upon to do other cool things with..
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    3 Discussions
    Thanks for clearing this up. I was a little mystified as well.
    I need like this when one momentory push button is presed once only one count get incremented and it goes to the respective process
    Just wondering why you've set an array of 4 items:
    yet you only setup and read from 3:
    If that's intentional then thats fine - just no comment noting why and some people might be confused.
