3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$2 Adjustable Fork-mounted Supplementary Bike Lights
I was looking for an inexpensive way to add supplementary lighting to the dynamo powered headlight on my new bike. After a very dark ride down the local Multi-use Path I knew I needed to add some more lights but I didn't want to clutter the handlebars with heavy and often expensive bicycle specific lights. The solution I came up with uses LED clip lights from the Dollar Tree and some stuff that you probably have laying around the house already.
I know there are already LOTS of home made bike lights on Instructables but this one is a little different. If nothing else, a light like this could add a certain 'bling' factor to your ride.
Step 1Materials and Tools
Materials and Tools
For this project you'll need:
Materials:
1 or more Dollar Tree 'LED Clip-On Spot Lights
Old bicycle innertube
2 zip ties per light
Tools:
Nipper Pliers (or Dremel w/ rotary cutter)
Scissors
Lighter (optional)
21 comments
Sep 11, 2011. 8:23 PMsgomes3 says:
This is cool Ryan. I didn't know you used a Dynamo. Are these supplementary lights dynamo or battery powered? Also be sure to check out my Dynamo Light project.
Cheers,
Sonnet.
Feb 23, 2010. 7:52 PMjet_ski says:
LOVE this idea. I am going to get a couple and put a red cellophane or other plastic filter on them and use them as rear lights to go on the rear uprights of my xtracycle... yay!
Oct 1, 2009. 2:34 PMtheguyfromplt says:
Only ONE thing I could add to this Instructable... Pop the lights out of the black "cups" and drill small holes into the side of the sockets for set screws... (I ride on some rough roads sometimes). I was mulling around today and saw these lights at Family Dollar (a dollar each - JUST like you said)! They look great, but I wish I had the same screws in the forks you do! :( Great idea though - they look sharp! Thanks!
Apr 3, 2009. 2:58 AMjames.mcglashan says:
u should use this with the Magnetic Induction Bike Lights (Mod) for ovious reasands
Oct 25, 2008. 6:24 AMjeff-o says:
Dollars stores are a fantastic source for cheap flashlights. The one close to me has 1W flashlights for a dollar, battery included!
Nov 5, 2008. 5:22 AMNotbob says:
Maybe so, but you can be sure that the battery is a cheap brand that no has ever heard of, and it wont last long.
Nov 5, 2008. 6:25 AMjeff-o says:
Well, it was a AA battery in this case, which are dirt cheap. It's the emitter that I was really after.
Nov 5, 2008. 7:17 AMNotbob says:
true, true...
Nov 1, 2008. 5:36 AMTopCatTC says:
I got some of these little lights. One thing may I suggest is once you have your lights installed on your bike put a dab of SUPERGLUE on the ball part of the light to stop them coming off I have already LOST two on my lights (maybe going over bumps?). Tom
Oct 23, 2008. 2:35 AMthepaul1993 says:
where do you get the dynamos
Oct 26, 2008. 9:44 PMthepaul1993 says:
ok, thanks
Jun 28, 2008. 9:18 PMNkevin90 says:
hey, that looks like an interesting bike; what'd you be riding there?
May 3, 2008. 9:47 PMgridnack-572 says:
i had some clip on lights just like the ones above. the only problem i had with was : 1- the batteries were very expensive to replace and 2- if the light were to get a good shock (like dropping it or hitting something) the thing would pop out of the socket/and fall to the floor/road
Oct 7, 2007. 12:07 PMPhoghat says:
I made a bikelight using a $10 Maglite flashlight from this site and mounted it to the handlebars. I bought a cyclometer and had no place to mount it. If I remove the light and mont it to the fork, it solves my problem.
Oct 5, 2007. 9:47 PMnedfunnell says:
How long do those little button cells last? Are you planning to mod them to run from the dynamo?
Oct 5, 2007. 12:08 PMve2vfd says:
Nice addition! Are those tiny lights bright enough to light your way?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Handsome-Ryan
