Introduction: $2 Carpet Broom
Picture of $2 Carpet Broom
Have you ever walked across a carpet only to sit down on your couch and find a rat's nest of hairs caught between your toes? Are you tired of toe flossing? I sure am!
I tried vacuuming, but it wouldn't cut it. I couldn't use a broom on carpet, unless. . .
With a spark of inspiration I pulled all of the hairs out from betwixt my toes and ran to Dollar Tree. With $2 and a few househould items I made the perfect device for my situation.
Step 1: Materials and Tools
Picture of Materials and Tools
Materials:
(Dollar Tree)
Tools:
  • Flat head screwdriver
  • Clamp
  • Gorilla glue
  • Sandpaper
Step 2: Disassemble Mop
Picture of Disassemble Mop
Using the flat head screwdriver I was able to pop the plastic end piece off of the mop and remove the cotton head. Maybe I'll find something to do with the cotton later.
Step 3: Sand and Glue
Picture of Sand and Glue
For better adhesion it's smart to rough up the surfaces beforehand. I used some 120 grit I had lying around.
After wiping away the dust I followed the instructions on the Gorilla Glue bottle, wiping one surface with water and applying glue to the other.
Step 4: Clamp It
Picture of Clamp It
Still following the directions I clamped the pieces together for two hours.
After that I unclamped the parts and waited 24 hours for the glue to set.
Step 5: Reassemble
Picture of Reassemble
Once the glue set I snapped the handle back onto my modified mop head and voila! A carpet broom is born.
Step 6: Get to Work!
Picture of Get to Work!
I now have complete control of the hairiness of my home's carpet! I take the broom out once a week or so to rid my home of the plague that is my fiancee's hair.
Step 7: Going Further
Picture of Going Further
A couple things I would do differently a second time around.
  1. Use a hand saw to remove the brush handle.
  2. Get a longer mop. I'm a tall guy so a cheap, short handle forces me to hunch over.
  3. Mount a hair roller to get shorter hairs, like my own.
  4. Find a use for the cotton mop head. Wig?
Jobar007 (author)2017-06-19
Do you pull or push the broom over the carpets?
Porda (author)Jobar0072017-06-20
Great question Jobar. I do a back and forth sweeping motion. I've also found a twist here and there helps to pick up the hairs. Otherwise you could end up just combing your carpet's hair.
Jobar007 (author)Porda2017-06-20
So what I'm hearing is that you sort of gently scrub the carpet with longer strokes?
About This Instructable
647views
5favorites
License:
Bio: Mechanical engineer, alumnus Colorado State University, and member of Alamance Makers Guild.
More by Porda:3D Print an ImagePorda Tri-SpinnerPorda Tri-Spinner
Add instructable to:
