Introduction: 2 Color Paracord Bracelet (Tutorial)
Step 1: Supplies
You will need 2 color paracords of your choosing and a buckle
Step 2:
After you chose the 2 colors I cut mine at 5ft just to have a safe length
Step 3:
Grab one of the colors and pull the core (the inside strands) of the paracord out just a little bit and cut it off so you would have a hollow shell type thing
Once you hollowed it out you need to slide the other color inside the hollow shell you made
Then singe the frayed part of the string like in the picture
Step 4:
Then loop the paracord through the sides of the buckle then adjust your bracelet size so that it will fit you
If you checked out my paracord bracelet tutorial down below that will come in handy
Step 5: Cobra Stitch/Weave
This 2 color bracelet will be the same exact thing as the other bracelet tutorial but with just 2 different colors
If you don't know the Cobra Stitch/Weave I suggest you check out my paracord bracelet tutorial below
Step 6:
Once you got that first one down just work your way down till you reach the buckle
Step 7: Finish
Once you reach the end cut the 2 ends and singe them with a lighter..make sure when you singe the ends that you make it smooth so it will be comfortable for you/family/friends wrist
Thanks for checking this out
\(^0^)/
