2 Dollar Zen Pendulum by spacepirate04
 A zen pendulum made out of simple materials
1.wooden bowl
2.coat hanger
3.sand
4.crystal with a point or metal cone with a point.
Browncoat says: Jul 30, 2012. 11:40 AM
I love this! I bet you could use sugar instead of sand. (If you don't have to worry about ants or other bugs.)
Did you drill a hole in the bowl & stick the hanger in it?
J@50n says: Jan 3, 2010. 8:03 AM
 Finished!
spacepirate04 (author) says: Jan 11, 2010. 11:32 AM
I went back and made a pivot like yours and it does swing better i`ll post pics of it  soon.
spacepirate04 (author) says: Jan 3, 2010. 9:42 AM
How well does it swing it?
J@50n says: Jan 3, 2010. 9:58 AM
 pretty well, i redid it just now though. more of the way frollard was sayin
J@50n says: Jan 3, 2010. 8:04 AM
 if you like the candles, the ible is....
www.instructables.com/id/Cookey-Candles/
frollard says: Jan 1, 2010. 3:51 PM
The zen pendulum requires one modification (to function like a proper one) - it needs the double pivot up top to bring one axis of movement's center up to the pivot point, and another just below it - this results in cooler patterns than 'just spirals'.
see...
I'm not saying you did it wrong, but a simple modification makes this a 2-dollar AWESOME pendulum :D
BrantFlakes315 says: Jan 3, 2010. 6:28 PM
Can you elaborate on this?
From what I understand you need a pivot on the top of the branch thingy, and then a loop, a ring, and another loop attached to the actual mass at the bottom. What should that pivot on top look like?
I really want to be able to build one of these the right way
frollard says: Jan 4, 2010. 4:58 AM
Look at the picture in my link - note how it has a 'reverse fork' that holds up the upper part, then the double ring attaches to that.  Whatever it does, it makes the pattern go from 'just spirals' to 'intricate triangles'
Look closely at the top - its not just a quicklink to a stationary point.
edit: Only reason I know is I made one back in high school - took forever to get it right, then I noticed it had the wrong pivot.  Quick bend some metal, and bam, perfect results.
J@50n says: Jan 2, 2010. 5:48 PM
 also, the official name of this is "The Sandpendel"
lemonie says: Jan 1, 2010. 3:49 PM
Could you explain how it works?
L
J@50n says: Jan 2, 2010. 4:33 PM
lemonie says: Jan 2, 2010. 4:44 PM
I'll phrase the question differently: Seeing a line traced in the sand, what is the significance of the mineral that is the pendulum, and the other three mineral pieces?
L
 its orange because it would not let me paste otherwise....
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
