Step 1: Assemble your supplies & get started.
A cheap foamy mattress pad from a discount store (about $9 for a twin, I bought a queen for $14)
Fabric, staple gun, staples, scissors, loooooong needle (teddy bear making supplies, upholstery needle, something like that)
Upholstery thread or some other really strong thread...fishing line could work, maybe.
Buttons, cotton batting or felt in a similar colour to your fabric ( only if you want covered buttons on your headboard)
Disposable chopsticks or bamboo skewers & pair of pliers
I measured my plywood and decided I wanted the headboard to be a smidge wider than the bed. I cut it into a 70"x33" rectangle.
You can get creative here and do all kinds of swoops and curly-cues in your headboard, just be forewarned, this will be a pain in the butt to staple your fabric around and have it look neat, tidy and non-bunched. Don't say I didn't warn you! A better idea, I think, is to splash out on some spendy fabric. You only need a couple of metres, so you can splurge on something really grand. The stripe I chose has a kind of pearly, organic, nature-y feel to it.
Decide now if you want to put buttons in your headboard. You can add them later, it's just easier to drill before adding the foam. I found the very centre and drilled a hole. I then went out to each side, 8", then made a diamond pattern, adding another row above and below the centre row. More on this later...
Lay your plywood out onto your foam. You may need to trim excess off in one spot and use that piece in another spot. You can see in the second image (at the bottom, right side) where my seam is. I didn't worry about glueing it or stapling it on the front. Overlapping it would leave a visible ripple through the fabric, so I simply butted the new piece up beside the other one. This worked well in the end and you'd never know I had to cut & paste my foam!
The staple job can be somewhat cursory at this point. You want to do a neat job when stapling on your fabric, but at this point, you just want the foam to stay put. No need to overdo it.
Step 2: Centre your headboard over your fabric piece.
Lay out your fabric on the floor, doing your best to smooth out any ripples or wrinkles. **Important** Make sure if your fabric has a right or wrong side, that the right side is facing the carpet.
Lay the headboard back down, centred over the fabric.
Step 3: Start stapling.
Tip it up and admire. You could quit right now and have a quality headboard on your hands! Well done!
Orrrr, you could say to yourself "that would look super swanky with some covered buttons!" as I did.
Step 4: Cover your buttons with fabric.
Get out your button jar and dig out some that are roughly the same size. I needed 13.
Cut out 13 little circles from your cotton batting or felt, then 13 (or however many you need) circles from your matching fabric.
Thread your needle and do a quick running stitch around the edge of the circle (as in photo 5). Set your cotton in the fabric circle, top with your button, then draw the thread tight and knot several times. Repeat until your buttons are all covered. This took me about 1/2 hour. You could totally skip this step and deck your headboard out with some cool, vintage buttons.
Step 5: Get ready to add your buttons
Get your bamboo skewers or chopsticks, your long needle, thread, your buttons and pliers.
In the second photo, you can see where I marked with a dried up old Sharpie, then later, for your benefit, an orange crayon, the holes I pre-drilled for the buttons. I don't know how big the drill bit was, but you don't want to be fishing around, blindly trying to pass the needle back through the tiniest of holes, so be sure the drill bit is around 1/16th to 1/8th". (I hope that makes sense & is not totally off the wall).
Step 6: Adding the buttons
First step: pull a long piece of your sturdy thread through your needle and knot it so that your thread is doubled.
Ok, starting on the back of the headboard, pass the threaded needle through to the front.
Pull it out the other side, but don't pull all of the thread through.
Pass the needle through the fabric button.
Push the needle back into the headboard and back through the hole to the back side.
You should have the knotted end of the thread hanging there. Poke a 2-3" piece of bamboo skewer through your two strands of thread and pull the needle towards you until the knot is held fast against the skewer, thus stopping the thread from pulling through to the other side and popping through the fabric, or leaving the button droopy.
Now cut the thread off your needle. Bring one tail of the thread around each side of the skewer and pull snug, knotting several times. Look over the other side to see how snug you want it pulled, and how tucked you want the button to be into the foam of the headboard.
Doing this step assembly-line style makes it go quicker.
Step 7: Hang that bad boy up!
We used a piece of 1x4 that DH ripped a diagonal cut lengthwise down it.
Put half on the wall and the other half will go on the back of your headboard. Locate your studs and insert one screw. Level it before putting the next screws in. Measure and decide where you want your headboard to sit on your wall. That is how you will decide where to mount the reciprocating half of the 1x4 on the headboard. Don't forget to level it as well.
Step 8: Stand back and admire!
We added some inexpensive IKEA lights at each end. It looks fantastic! Get ready to tour all the neighbours through your bedroom! You're gonna want to show it off, just pick up the dirty socks beforehand.
jessandstavro (author)
says:
Apr 21, 2013. 9:36 AMReply
bigjohn1a
says:
Jun 4, 2012. 8:56 AMReply
in reply to Jun 4, 2012. 9:35 AMReply
mikeasaurus
says:
Oct 5, 2011. 10:13 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
