Introduction: 2" Round PVC Knitting Loom
Materials:
(1) 2" PVC bushing
(8) 2" x 8 exterior screws
Tools:
Electric drill, 1/8” or 3/16" drill bit
angle grinder/dykes/saw
Step 1: Drill, Baby, Drill.
Mark the top of your bushing at 8 evenly spaced points, roughly 2/3 toward the outside edge. The bottom of the bushing is an octagon, so you can plan on drilling at each point.
Use your 1/8” drill to make holes all the way vertically through the bushing.
Step 2: Screwing Around
Screw in your stainless steel screws. We want to leave only the smooth, non-threaded part of the shaft sticking out of the top side of the loom. Initially this leaves a sharp point sticking out the bottom. Oh Noes!
Step 3: Nerfing the Loom
In order to reduce the pokeyness of the bottom of the loom, screw the screws in an extra turn, use an angle grinder / saw / dykes to cut off the sharp tips of the screws.
Turn the screws out to where the end of the smooth part of the shaft is once again flush with the top of the loom. This should draw the newly shortened ends of the screws up into their holes.
Now you're ready to knit!
Step 4: KNIT!!!
These looms are great for making long chains which can then be used to arm knit/crochet.
They can also be used to single knit flat panels, which can be alternated with knitting in the round if so desired.
