Rather than pay a gym membership, it saves time and money to go running outside. Running barefoot, a lot of evidence shows, is how are bodies were meant to run. But I worry about broken glass and gravel, so I need something to protect my tender soles.
I bought some Vibram Five-Fingers that are a tad too small on my right foot, so they crush my toes. I have been running in socks recently but they wear out quickly. So I tried making some running shoes with socks and hot glue. It's ridiculous, but it works, and it was fast to make them.
Materials and tools:
Cardboard to cut foot shape out of
Sharpie to trace feet
Scissors and stapler to build foot molds
1 Pair of socks
About 9 sticks of high temperature hot glue
Camping stove or something else to melt glue
Cookie sheet
Parchment paper or wax paper to melt glue on
Takes about 15-30 minutes
Remove these ads by
Signing UpStep 1Making Cardboard Cutouts of Your Feet
2. Cut the shapes out with scissors and even them out by stacking them on top of one another.
*I found out that I traced my heels a little too loosely, so the base of the heel of the sock was a little too broad for my feet. Trace the heels of your feet more tightly to achieve a better fit.
tabi is the traditional ninja footwear, like a sock but more firm, less elastic and seperates the big toe from the other toes. I think It's better than a simple sock-in-glue becouse you have better feel of the ground and balance
Plus you can put on flip-flops!
Thanks so much!!
also instead of gas stove, I use a hot air gun initially at 190 C (~380 F) but it was going slow so I cranked it up to 350 C (~660 F) to melt the glue in a disposable aluminium tray.
When I was finished with the "main" covering of the sole I did some finishing with the hot air on the sock at 400 C (~750 F) to quickly and locally achieve a smooth clean surface.
Yet i don't recoment going that far with the temp, becouse the glue fumes a little so you need good ventilation, plus one of the socks got charred at a couple of spots and it required some sewing...
Better luck next time
they are great, durable with amazing traction!!!
you sure get to fill a bit of a ninja even wearing them while doing the dishes!
Also, my glue hardly gets any traction whatsoever (this may be because the soles contain a high concentration of dirt and pebbles) What brand of glue did you use?
Perhaps you should try covering the glue sole with something else, like polystyrene or polyourethane...
I use them mainly indoors, that's why they will be looking good for a long time, plus I am still on a desinging phase. The more I wear them the more flaws I discover. When I will perfect the desing I will deal with durability...
hot melt is hit and miss. It bonds well to some soles but not others. Surface prep doesn't seem to matter much, of course clean them well etc., but abrading and or heating first doesn't seem to matter much; it either sticks or it doesn't. Even within the same brand line some stick and others don't so it doesn't seem to be caused by sole material, just planetary alignment.
It's always been an issue of 'I have it here, I don't have to run to the store, and I don't have to wait for it to dry, so I'll try it.'
