Step 3Melt the glue and dip the socks
1. Prepare your heat source (I used an outdoor camping stove)
2. Cover your cookie sheet with parchment paper or wax paper
3. Place your glue sticks evenly along the whole length that you need to dip the socks
4. Slowly and carefully melt them on low heat (I burned some of the parchment paper by accident)
5. Once melted, remove the glue from the heat source and press the whole bottom of the sock onto it, remove and check for an even coating (push the sock at every location for a total of about 30 seconds)
6. Dry the glue bottom up*
7. Repeat steps 3-6 for the other sock
*or for #6 you can try setting the socks glue down on a sheet of parchment paper or wax paper. As you can see in the last picture in this step, it peels of easily and creates a flat running surface
comment
Add Comment
Add Comment
