3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
2-day $20-$50 Blacksmithing Forge
A How-To on how to make a small forge
Step 1The Stuff
The Stuff
Clay- From a potters-shop
Fan- From one of those tacky iflatible palm trees
Metal Chair- I got one from my church
Safety Wire- $5-$10 at hardware shops
Big Speaker- Found an old steel one at my church as well
Quickcrete- $3 on sale
Light Fixture- Got an old one from my chicken coop ($5 new)
Steel Pipe- Found behind my church, probably could be found at a junkyard
Tire Rim- can be found at a junkyard to
A Hack Saw- Every man should have one of these
I think that covers it- on to Step 2
62 comments
1-40 of 62next »
May 16, 2009. 5:06 AMEvilblaze says:
Wow, nice instructable. What do you think, can I make a foundry to melt titanium with a similar way like this? The titanium melts at 1700 Celsius, it means much more heat needed than in this case (aluminum melting).
The titanium is produced this way: http://www.instructables.com/id/How-to-make-titanium-metal/
Sep 29, 2011. 4:17 PMsnowluck2345 says:
no, you would have to seal the titanium in an inert environment or it would combust.
Jun 4, 2011. 6:29 PM_Scratch_ says:
Wow, your church has a lot of junk...
Nov 12, 2008. 3:09 PMjjhammerstein says:
It's much easier to use a brake drum from a truck for your fire bowl. I found mine on the side of the highway somewhere. It has the same thermal mass qualities, and I'm pretty sure junk car lots are easier to find than pottery supply shops. Cheaper too.
Feb 24, 2010. 10:02 PMseabee890 says:
the blacksmith that was teaching me used the top of a old water heater tank(the inside not the outside, this made a natural cleanout hole at the bottom. I miss the smell of burning coal sometimes.
Feb 25, 2010. 5:21 PMseabee890 says:
my goal is to find a way to create a power hammer without  the weight and space, i was going to use a cherry picker and a jack hammer  set up so that i could custom make the bits but i have not got the space for a shop yet.
Oct 19, 2010. 6:38 PMbadideasrus says:
a possibly more complicated way to do it may be to observe some clock movements. use a pendulum and gear setup to lift and drop a hammer. need big weight on the pendulum tho.....
also, i a blacksmith book i bought, there was an 'un' powered hammer that used ur foot to hammer. maybe i draw a pic, if i can figure out how to upload one. basically, hammer is on an axle. a leaf spring (which was made of wood in the pic) was attached to a chain, rope, ect, looped over a pully and attached to the hammer.
another chain-thing was attached to the axle (or an arm attached to the axle, for more leverage....). the other end of the chain was attached to a foot pedal. hands are free to manover the metal and such, while the foot moved the hammer.
Jul 23, 2011. 12:59 PMDemascus says:
you use a electric motor, and the spring for a car or truck the gears and stuff are not really needed unless you want to make it a multi speed unit.
you make a cam our of a piece of square steel tubing . can also be made out of a large square piece of wood. the spring with hammer head on the end is held down on the other end and it rests on the square tubing. AS the motor turns the tubing is acts like a cam and raises the piece and lets it fall. Germans had one that used a water wheel and large logs that Ka thunked down with steel heads to pound their steel. I can makes some drawing if anyone needs more visiable information
Nov 18, 2008. 10:27 AMn0ukf says:
Why would you want thermal mass in your firepot? More thermal mass takes more energy (more coal) to heat. Also, while the wider pot of a truck brake drum would give you more working area for the 'fire', you don't want the pot very deep if you want to heat anything very long (like say, a larger dagger or sword for the blade makers).
I've tried to work with a deep firepot, but to heat the middle of a longer piece, I had to either build the fire way up or bend the piece to get it down into the coals (coke). That's why so many smiths will have a more table type forge with the fire built up more in a pile. There is a firepot below the surface, but it's not that deep.
You can go to Anvilfire to learn more, they're very helpful there.
Nov 15, 2008. 6:56 AMStarshock01 says:
yeah while brake drum forges are nice they have barely enough room to make a decent knife, unless your using a monster truck drum
Nov 15, 2008. 3:34 PMjjhammerstein says:
I use a monster brake drum. :D
Apr 23, 2011. 7:38 PMDemascus says:
me too, made 2ft by 3 ft long table out of angle iron and 1/8 inch steel plate for the table bed, cut a hole in it just big enough to allow the brake drum to sit down in it and is held by that little rim on the outside edge all brake drums have. Use a large table fitting about 2inch diam pipe drilled holes in the inside edge of the brake drum (where the tire mounting nuts go.) used clay to pack a little bit around it and then made a 1/2 inch thick plate with holes in that set on the bottom. and I use coal, once it is started I keep adding more til it makes a mole hill in the middle of the forge. You use a watering sprinkler can to wet down the coal and keeps the fire from spreading also makes it coke up in there. I punch a little hole in the side of it and creates a "little cave" that way I can see my stuff and not melt it off. (yes I have done that) with just coal and air the thing gets over 3,000 degrees inside it will burn steel.literally
Apr 20, 2011. 5:52 PMDumchicken says:
you mean inflatable
Jan 8, 2011. 11:02 AMjakenzi357 says:
i died.
Nov 17, 2008. 3:04 PMichbinoadie says:
Slow-curing something like this is VERY important. I might also suggest you put some thick perforated plate or a bar stock grid over the hole. Clinkers will clog that in minutes if you ever managed to fire coal in there. It also looks a bit deep to me. You don't need anything larger than a brake drum for a small-ish forge because without a large series of tuyeres (air holes), only a small area of fuel is getting sufficiently heated, anyway. A metal table built around the brake drum holds extra fuel to be raked in as needed. I'd be curious as to just how hot this thing actually gets. What size bar stock did you heat in that pic? I know from experience that you can get thinner stock well past cherry red in an old Weber kettle grill with commercial charcoal briquettes. Heck, you can smelt with nothing but mud, clay, and bellows. Not easy or efficient, but doable. Hope my commentary was at least mildly constructive. Great to see people actively DIYing blacksmithing/casting type projects. Finally, a disclaimer: My comments are mostly scholarly, not experiential. Hard to play with fire on almost any scale in a rented house with no yard right off a commercial street in a college town. But I've done my homework relatively thoroughly and have spoken with several people quite in the know. Take it or leave it.
Nov 27, 2008. 8:24 AMredhand rik says:
what you need for a thermometer is a pyrometer... it's the same thing but a much higher temperature capacity... be careful though, they can damage your wallet . with experience you can guesstimate temp by color. that's what was used throughout history
Oct 19, 2010. 6:47 PMbadideasrus says:
why not get an infrared thermometer. i think i've seen a couple cheap ones somewere....
May 27, 2010. 4:16 PMCube Steak says:
Ouch.... not nice.... And Isaac, your such a freak Haha....
Feb 8, 2010. 4:46 PMpigpenguin says:
 this may sound stupid and out of place, but you said in the instructable that you can get a bike rim from a junkyard, how does that work i can't seem to find any help on that....
Sep 29, 2009. 12:44 PMRoger4Wheel says:
He didn't use concrete (sand cement and gravel). He used mortar mix (sand cement and lime). quick-crete, kwick-crete, and others are just BRANDS of concrete type products. If you have a bunch of fire brick (broken or not) from an old chimney or fireplace, you can break then grind it up into a course powder and when mixed with fireplace mortar will make a nice mix to use for forges (not for iron or steel melting)
Jul 24, 2009. 10:14 PMpetzlglyph says:
Fire clay is available from most masonry suppliers it is used for building fireplaces. I should be fired before it dry's out. I just used it to build a melting furnace and had no problems with exploding, just a few small cracks into which I placed more fire clay before the next firing. I used a mixture of two parts 60 grit silica sand and one part fire clay. The first firing needs to be a long one to cure the fire clay. I filled it with charcoal ( Bar-B-Que type ), light the charcoal and let burn till all of it is ignited ( lots of steam will form ). Then turn on the blower ( low if possible ) until all of the charcoal is consumed. then cover the top with a ( dry ) stepping stone or something non combustable to hold in the heat until it cools on it's own. The charcoal produces nasty fumes do this outside. Great Instructable, I like your use of available resources!
Dec 31, 2008. 8:44 AMDiverguy83 says:
i dont know about using concrete cause that crap explodes when heated to high temps ... i just went to the pottery shop and got some fireclay for pretty cheap plus i use a brake drum and i havent had any problems making knives with it.
Jun 20, 2009. 3:33 AMskaar says:
if you look at the diy foundry sites, you'll find that a mix of cement and vermiculite works well as a refractory, so it, can't be too bad to use cement. i think maybe it's the rocks in concrete that crack, but there's no rocks in the clay/cement mix.
Mar 8, 2009. 1:14 PMgrimcat27 says:
you can use kitty litter but it has to be crushed up first. It will not work whole an old blender and some window screen works well and oh yeah some time and Patience too. (maybe an hour or two to get a few LBS )
Sep 9, 2010. 9:00 AMseabee890 says:
!WARNING! USE THE BLENDER IDEA ONLY IF YOU WANT THE MISSUS TO DRAG YOU TO THE LOCAL APPLIANCE STORE BECAUSE SHE CAUGHT YOU USING THE BLENDER TO GRIND UP KITTY LITTER>>>> It was an old blender but I still felt like a kid getting caught playing with matches.
Jan 5, 2009. 8:34 AMDiverguy83 says:
no i keep mine in the garage but as far as the fireclay goes i just looked up a rinker materials plant and picked up a 50 pound bag for about 23 bucks after taxes.
Apr 4, 2009. 3:37 PMThundertydus says:
Damn, I Died.. If i could sue you... Hmmm..
Mar 24, 2009. 12:46 AMtrf says:
i used refractory cement...proably the most durable thing there is for a forge. Put some in a wheelbarrow and add water till u get the consistency you want. I kept mine stiff. I just globbed it in there and smoothed it out. If youd like to see my forge, visit http://www.instructables.com/id/How_To_Make_A_Bladesmiths_Forge/ .
I will be adding more pictures of usage and such in the coming days on my next project.
Dec 3, 2008. 4:20 PMebothwell1 says:
This will work, but I would add a few more safety and performance caveats.
1. Concrete is not refractory. It will fail eventually; quite possibly not at a good time. Be certain to allow a bunch of old coal to be between the fire and the concrete to try and keep it from over heating.
2. The rocks in the concrete may not be the right type; this is especially a risk with quickcrete. Some rocks explode when heated. Not usual, but possible. Best to use a cement which is heavy on sand rather than rocks
3. Yes, as ichbinoadie notes, the concrete must be completely cured before using the forge. Otherwise it will steam, and possibly pop or explode.
4. jjhammerstein et al note a break drum forge is an good option for a home made forge. It is designed for a higher temp tolerance than concrete.
Remember, things that unexpectedly go boom are bad...
Dec 7, 2008. 9:17 PMn0ukf says:
One reason rocks explode in fire is because of trapped moisture becoming steam. I've seen rocks from the lake shore explode when used to ring a fire due to the steam pressure. Before you start forging with a lined firepot, you'll want to make sure the lining is fully dry. The thicker it is, the longer it needs to dry. Just because concrete or furnace cement is hard, doesn't mean it's dry yet.
1-40 of 62next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:OldOwlIronworks
