Remove these ads by
Signing UpStep 1The Stuff
Fan- From one of those tacky iflatible palm trees
Metal Chair- I got one from my church
Safety Wire- $5-$10 at hardware shops
Big Speaker- Found an old steel one at my church as well
Quickcrete- $3 on sale
Light Fixture- Got an old one from my chicken coop ($5 new)
Steel Pipe- Found behind my church, probably could be found at a junkyard
Tire Rim- can be found at a junkyard to
A Hack Saw- Every man should have one of these
I think that covers it- on to Step 2
The titanium is produced this way: http://www.instructables.com/id/How-to-make-titanium-metal/
also, i a blacksmith book i bought, there was an 'un' powered hammer that used ur foot to hammer. maybe i draw a pic, if i can figure out how to upload one. basically, hammer is on an axle. a leaf spring (which was made of wood in the pic) was attached to a chain, rope, ect, looped over a pully and attached to the hammer.
another chain-thing was attached to the axle (or an arm attached to the axle, for more leverage....). the other end of the chain was attached to a foot pedal. hands are free to manover the metal and such, while the foot moved the hammer.
you make a cam our of a piece of square steel tubing . can also be made out of a large square piece of wood. the spring with hammer head on the end is held down on the other end and it rests on the square tubing. AS the motor turns the tubing is acts like a cam and raises the piece and lets it fall. Germans had one that used a water wheel and large logs that Ka thunked down with steel heads to pound their steel. I can makes some drawing if anyone needs more visiable information
I've tried to work with a deep firepot, but to heat the middle of a longer piece, I had to either build the fire way up or bend the piece to get it down into the coals (coke). That's why so many smiths will have a more table type forge with the fire built up more in a pile. There is a firepot below the surface, but it's not that deep.
You can go to Anvilfire to learn more, they're very helpful there.
I will be adding more pictures of usage and such in the coming days on my next project.
1. Concrete is not refractory. It will fail eventually; quite possibly not at a good time. Be certain to allow a bunch of old coal to be between the fire and the concrete to try and keep it from over heating.
2. The rocks in the concrete may not be the right type; this is especially a risk with quickcrete. Some rocks explode when heated. Not usual, but possible. Best to use a cement which is heavy on sand rather than rocks
3. Yes, as ichbinoadie notes, the concrete must be completely cured before using the forge. Otherwise it will steam, and possibly pop or explode.
4. jjhammerstein et al note a break drum forge is an good option for a home made forge. It is designed for a higher temp tolerance than concrete.
Remember, things that unexpectedly go boom are bad...
