3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
2 meter flying RC starship Enterprise
To boldly go where no airship has gone before... an indoor flying sculpture of the starship Enterprise.
It's not a representation of a particular version of the Enterprise, but an "artist's impression" of the yet unappeared Enterprise Z (Z from Zeppelin) .
Check out the video to see how it moves around:
I made it for the occasion of the BVC participation at the 20th F.A.C.T.S. convention in Ghent, October 23-24, 2010. The BVC or Belgian Voyage Club is the Belgian Star Trek fan club (www.bvc.be). And it's flying again at the 21st F.A.C.T.S. convention in Ghent, October 22-23, 2011.
In this Ible I explain how I made the construction. I also explain the main principles of the build of a vectored thrust propulsion (propellers moving in the direction you want thrust) and tail motor steering. The exact solution is however depending on what RC-components you have available.
Thanks for the votes in the Autodesk Kinetic Sculpture Design Contest!
Step 1Materials
Materials
It is quite possible to make blimp envelopes yourself, but I never reached the helium tightness of industrially made balloons. Also the “valve” used by commercial balloons is hard to match in ease of use and tightness. Therefore I based my project on ready made balloons:
Two Zeppelin NT foil balloons, available at the webshop from the Deutsche Zeppelin Reederei.
A 52” blimp envelope, as common for toy RC Blimps. I actually used a 52” x 37” version with extra load bearing capacity. This allowed to add more trimming weight and removing it to compensate for helium loss over time.
A 36 or 38” round foil balloon (as sold for toy RC “flying saucer” blimps or large decorative balloons).
About 2 to 3 m2 of balloon foil (I used a type with one side in white, matching the main hull, but a silver coloured Enterprise Z would look great too).
The last to items could be replaced by an "Amazing Indoor Anti-Gravity Flying Disc", if you can find one.
Similar flying discs are available, but these are smaller and come in colourfull prints not suited for this project.
99%+ pure helium for maximum buoyancy. For small quantities I find it cheapest and easiest to have my balloons filled at the local balloon shop. Balloon Surprise in Drongen gives excellent service.
Construction material:
Some extruded polystyrene sheet (mostly known under the brand name “Depron”, about 0.5 m2 of 5-6 mm thickness and 0.5 m2 of 3 mm thickness.
about 3.5 m of 2 mm diameter glassfiber composite rod (as available from kite shops) or, even probably better probably about 1.5mm carbon composite rod.
Polystyrene contact glue. The clear type is preferred, but as I didn't have that available some camouflaging was done at the end with white acrylic paint.
Some superglue
Clear cellotape, wide and standard
Thin double sided tape (the carpet fixing type).
A printer and paper (as light as your printer accepts is best, but I used ordinary office paper)
About 50g of plasticine as trimming weight (no play dough, as this tends to dry out and lose weight)
Propulsion and control:
The propulsion and RC components should be under 40g. I used an 8g parkflyer receiver, three 6g micro servos, an extra motor from such a servo, a 10g LiPo battery and three 6.5 diameter indoor airplane propellers. To that I added , two small gears with a 1 to 3 ratio (4 is even better), some 2mm diameter carbon rod (a piece of 20 cm and one of 40 cm), an a extra small micro switc and about 2.5 m of the thinnest isolated electric wire I could find.
31 comments
Nov 14, 2010. 9:00 AMrcsuperhero says:
Neat! I like unique flying projects! I wish the disk part was more to scale (larger)
also check out my flying man rcsuperhero see him on youtube
Im a big star track fan!
Dec 10, 2011. 8:13 AMthe dashing hero says:
*trek*
Nov 14, 2010. 12:10 PMplayer2756 says:
Cool, but i was really expecting jet motors...
Nov 14, 2010. 7:39 PMroland985 says:
Or warp drive, Hehe
Aug 12, 2011. 11:13 AMspizman says:
Then how about Trans-Warp?
Nov 15, 2010. 1:18 AMroland985 says:
Just Impulse then?
Nov 15, 2010. 2:17 PMplayer2756 says:
still very awesome
Apr 11, 2011. 9:09 PMbabylon5 says:
That was cool video. I am into RC flying so that RC Starship enterprise rocks!
Jan 15, 2011. 3:24 AMbongodrummer says:
Great! Loving that old school style. Listening to that video sure did bring back some memories :)
Dec 21, 2010. 9:30 PMfrikkie says:
Freaken Awesome! Man i love this one!
Nov 29, 2010. 4:36 PMthevansleaving says:
That was awesome, you got my vote :]
Nov 29, 2010. 10:11 AMdrslump says:
you have a vote from me
Nov 17, 2010. 2:52 AMx7319808 says:
Sub-Light is a little more accurate.
Nov 10, 2010. 10:13 PMPaulMakesThings says:
Pretty clever. Isn't there some way to heat seal mylar?
Nov 14, 2010. 8:28 AMmnpazan says:
Were you able to tell why the DIY balloons had a higher loss rate? Was it the seal or the material?
Nov 15, 2010. 1:19 AMroland985 says:
No, just the odd hull breach...
Nov 13, 2010. 11:07 PMwareneutron says:
so many materials that you need in one 2 meter flying RC starship
Nov 14, 2010. 6:44 AMbertjes says:
great stuff, I have seen it in Gent
and it flys verry high (beware for the hights)
Nov 14, 2010. 10:55 AMmikegalloway says:
Simply... awesome.
Nov 14, 2010. 9:15 AM9ale7 says:
i love the slow movements ,
looks like the real thing :)
Nov 10, 2010. 5:52 PMMr.NHRA says:
Very Nice!
Nov 9, 2010. 11:37 PMTreasure Tabby says:
Neat-o :D
Nov 9, 2010. 6:04 PMrimar2000 says:
Beautiful! Congratulations.
Nov 9, 2010. 2:23 PMkelseymh says:
Now that is a transporter full of WIN. Thank you for posting all of the details!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
