3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
simple wired 2 motor control joystick
i wanted for a long time to have a control joystick(control box), wich can easy change the directions of 2 motors. so i made one. it's not hard to build and works perfect. the costs vary between 2 and 4 euro. feel free to change/improve the project using creativity and better parts. share your experience! i hope my bad english won't be an obstacle ( i have a lot of pics though :).
so have fun building the two motor control joystick!
Step 1The idea
the idea
on the schematic i use 1-pole pushbuttons (0.20euro/unit), but that's only because the 2-pole ones were too expensive (3euro/unit). so i had to group them to change the polarity. i also used a bit different schematic, but only because i didn't know, that these pushbuttons have 4 usable pins(you'll see what i mean on the 3th step). this schematic work too, but it can be a bit more complicated to build.
33 comments
Jul 27, 2008. 6:43 AMLftndbt says:
Interesting.... I may have an application for that at the moment.
I would be interested to see you try this setup out on a future project...
The nature of the dial allows for almost instantanious switchs.My finger model
I'm going to try your idea out now... Thanks heaps!!
Sep 6, 2008. 7:10 PMFred82664 says:
hummm one could use a hollow tubing and insert a small POT with a wheel on top of the stick and run it in series with the push buttons thus would make the output variable. the stick could be made from a short length of Automobile brake line. cut threads in to the OD and still use the nut and washer method to mate the push button switches. never the less this is a cool project and would be vary useful for manual testing on individual robotic system (s) parts of a single robot or other testing applications
Sep 7, 2008. 5:32 AMDerin says:
this is constructive criticism,btw. item 7 is called a washer
Feb 12, 2009. 9:22 PMwethecom says:
simple an effective i like it
back in the day of commodores "really old computers just in case your to young to know" i would buy controllers for them they were similar to atari controllers
and this is the part that may help you out a bit
they actually used tire stems for the joy sticks ..bonus part is you can buy cool tire stem caps that look really cool
check it out ...when you see it i bet it clicks in your head what im talking about
http://www.sciencetoymaker.org/waterRocket/images/tireStem.JPG
Jul 2, 2011. 11:20 PMaxeman911 says:
is there some way to make so that u can make both motors run at the same time, or some way to use it to control a tank with individual left right motors??
Jul 3, 2011. 6:15 PMaxeman911 says:
thanks would an h-bridge also work link:
http://en.wikipedia.org/wiki/H-bridge
Apr 1, 2010. 11:40 PMmyxpykalix says:
Hello! Could you tell me the title and artist of the music you used in the background? Good instructable thanks!
Nov 9, 2010. 12:39 PMUdon says:
This is very, very cool.
Opens up all kinds of possibilities.
Apr 2, 2010. 12:35 PMtomtom4388 says:
this is actually an h-bridge
nice idea, but you have to be careful, if you press back and forward buttons at once you short-circuit your power source
when using small batteries not too much trouble, but when using an big power supply you risk burning your switch or wires
Mar 31, 2010. 5:53 PMkcls says:
I've been looking around for something to control a mini prize claw. This would be perfect! Thanks for the great 'ible!
Mar 31, 2010. 11:09 AMpunkhead58 says:
By any chance, could Part 7 be a washer?
Mar 31, 2010. 5:41 PMPatented says:
thats what I am thinking..
Mar 31, 2010. 4:31 PMfruitkid101 says:
You could use this to control a 3axis milling maching with regular motors instead of steepers. BTW what kind of motors are the ones you use. DC?
Jul 30, 2008. 7:54 AMthor44 says:
Nice...if i wanted to do this with a higher battery voltage, say a small 12v battery, would i need to change anything, like the wire gauge or etc..
Oct 13, 2008. 3:04 PMomnibot says:
I'd say the easy way would be to just scale up, use switches and cables for 12 volt. The cool way would be to use relays closer to the motors.
Mar 14, 2009. 1:54 AMgodfreyandthandi says:
seconded!
Feb 12, 2009. 12:04 PMbombmaker2 says:
could u upload a new schematic like the one u used
Oct 21, 2009. 1:54 PMDELETED_madscientist167 says:
(removed by author or community request)
Feb 14, 2009. 2:00 PMbombmaker2 says:
k thanks
Dec 18, 2008. 3:22 AMfalcotheimpaler says:
this puts every idea i've had on this manner to shame. it's better than an h-bridge, and simpler than a microcontroller.
Aug 8, 2008. 7:28 AMmario59 says:
Your INSTRUCTABLE is really *NEAT* !!!!
I love simple idea to solve otherwise a bit complicated problems.
I have to say I NEVER THOUGHT about such circuitry before!
I think, if not patented, it should!!!
CONGRATULATIONS!!!
Jul 23, 2008. 10:16 PMdchall8 says:
Not to take anything away from your project, but I like to plant this seed where it seems to fit. I'd like to see some electronic genius convert a $30 game controller into a real radio control device.
Jul 27, 2008. 6:38 AMLftndbt says:
I will be soon, but seems a tad overdone on the net of late. Would be good to see one at Ible's though. ;)
Jul 23, 2008. 8:12 PMfrollard says:
That's a neat little project - It looks at first like its variable speed - but thats just the motors spinning up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:little_spiro
