3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
2 storey compost bin!
Step 4Bricking up higher
Bricking up higher
I increased the size in front and raised up the bricks to a new height. I used old shabby bricks that i had found in the ground (old steps in their garden, I guess) and did not try to do a very nice job.
If you do it, put a piece of ply across the front so you can bring the front bricks exactly flush with the plywood. I finished it off level on top. I went 8 bricks high and this has worked very well for me (6 ft one high). I think for average people 7 bricks high is good.
My original heap was on a concrete pad that was already there but it sloped to the back and made wet compost. I added concrete inside so that it sloped slightly to the front so no more drainage problems!
(I smoothed it flat after I took the photo).
The brickwork was laid on a mix of 3 parts fine sand to 1 part type s cement. It is made to a consistancy like stiff pie mix. You can trowel a "wave" onto the mix in the wheelbarrow and it will stay up. (Wetter than that and the bricks tend to sink).
In a pinch you can use type 10 cement or type n.
It will not be ideal but if you have a little that is going to waste, use it!
It is only a composter!
You could also make the bottom of the composter from stone with any of the different cement types in your mortar. 3 sand to 1 cement mix for this job in stone too. And you can have the mortar a little drier if you use stone. (Brick sucks the moisture out and drys the mix quick), stone does not suck the moisture out much.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
