Step 7Adding the "door" and "lid"
It could be quite a problem!
I ended up attaching it with a bit of clothes line wrapped around the back of the bricks. The clothesline has a tightener that you twist to get it really tight. Let off the tension a little to remove the door and take away your finished compost. (I made the door from an old pallet) The lid was a piece of plywood. Luckily it slipped under the front of the concrete ring a bit! It is not attached to the door but is held in place because it slipped in so nicely under the ring. If you loosen the door a little, you can easily take off the lid as shown in picture 2 and picture 3
Add Comment
