I just moved to Chicago, and, while I look for full time work, I have started volunteering at the ReBuilding Exchange ( http://www.rebuildingexchange.org.)  They are an salvage warehouse, selling architectural elements from demolished houses, furniture made from reclaimed lumber, and old, but still useable appliances.  RX also trains ex-offenders in job skills, including woodworking.  I've written some more about their work and my participation in it on my new blog, found here:  http://www.objectguerilla.blogspot.com.
Their furniture line, RX Made, concentrates on fairly simple furniture pieces that can be built from what they have available in the warehouse.  Complicated cuts, fancy joinery, and fine finishing are outside the skill level of the job trainees and the tools available in their still-new workshop.
Their current bench design is simple and straightforward, but relies on end-grain joints of questionable strength.  I prototyped some new benches for them, three in all, in an attempt to reduce the amount of materials, store-bought fasteners, and time needed to make each one.  You can knock these out in an afternoon, providing some solid seating for your mudroom or deck.  They are a great beginner's project that will acquaint you with a few common power tools and give you a dose of confidence so you can move on to something more complex.  Even if you buy the materials off-the-shelf, each one of these benches is super-cheap so you don't have to worry about messing up.  Lastly, don't be intimidated by the tools list: you can build all three of these with nothing more than a drill and a circular saw if that's all you have available.
These directions concentrate on the two benches that utilize grooves to hold the legs in place; the lag-bolted version is fairly self-explanatory from the pictures.  Just cut some slanted legs and shoot it through with big fasteners.
You will need these materials:
1 2" x 10" x 8' board per bench
1 2" x 4" x 4' board per bench
A handful of 2-1/2" drywall or deck screws
A handful of 3/8" x 5" lag bolts and washers
Some thin scrap wood
You will need these tools:
Chop saw or circular saw
Drill/driver
Router with flush trim bit
Power sander
Assorted bits appropriate to your fasteners
Mallet
Clamps
Tape measure
Square
Pencil
Step 1: Cutting and Sanding
First, cut the tops for your benches.  These are 48" long.  That length makes space for a few people to sit on them, and also allows you to get both the top and two legs out of one eight-foot board.
Use a chop saw, if you have one, for a nice square cut.  I take an inch or two off the factory ends to re-square and clean up the board, as those ends can often be rather rough.
Take a sander to the tops with 60, 80, or 100 grit paper, depending on the condition of the lumber.  If you are planning to finish the wood
-- if the benches are for outdoor use, for instance -- work your way up to a 120 grit for a super-smooth surface.  The screwdriver in the second picture was used to lever out old staples, a hazard of using reclaimed wood.
mjursic says: Sep 11, 2011. 7:24 AM
This is a great project and one I've been working on as well.
Here's my solution to the lag-bolt counterbore problem: I used a 3/4" speedbore spade bit for the hole, and drilled it to 1/4". Insert the lagbolt with glue in the dadoes, and tighten up the lags . THEN I used the end of a broomstick I had hanging around for a plug. Sawed it off with a dozuki, though a regular saw would work if you were careful, and sanded it flush. Looks great too. When I did it on a smaller scale to build a stepstool, people ask me if I put the whole thing together with pins. I'll see if I can post a pic.
I love the look of finished old red pine. Beautiful with a coat of linseed oil.
DIY-Guy in reply to mjursicNov 24, 2011. 12:39 PM
MJursic: Do you mind posting a picture of this which you just described?
Thanks!
mr.squeakers says: Oct 2, 2011. 5:19 PM
These are very cool.
static says: Sep 14, 2011. 8:28 PM
Nice. However in a nation where if the users aren't a lard butt they may be 6' + tall who may be heavy even if they are trim, I'd move the 2x4 down lower to make a proper leg stretcher. I'd probably make the leg to seat connection stronger as well.
wholman (author) in reply to staticSep 15, 2011. 4:29 AM
In may seem counter-intuitive, but keep the stretcher where it is! If you move it down, you'll just create a big parallelogram that will collapse when anyone sits on it, lard butt or no. Trust me, you could drive a Mack truck onto these things just as they are.
Ortzinator says: Sep 14, 2011. 8:13 PM
Where do you find this bit? I only ever see them with the bearing on the end.
josephthorpwausau says: Sep 12, 2011. 7:37 PM
looks like a great project for just about anyone looks real ez to do way to go anything to get people wood working is awesome !
MattDoesThat in reply to josephthorpwausauSep 14, 2011. 3:10 PM
I did typo that, didn't I? Perhaps I have an aversion to lice. Lol
MattDoesThat says: Sep 11, 2011. 8:19 AM
Love the design. Your grooves are not grooves by the way. They are dados. I know I'm knit picking.
static in reply to MattDoesThatSep 14, 2011. 2:26 PM
Nitpicking, not knit picking, to nitpick ;) The author know they are dados, must be keeping the terminology simple for noob wood workers?
ikoglin says: Sep 12, 2011. 12:08 AM
this looks like the perfect idea for the wood lying around in our shed... Thanks for that great instruction!
Chumlee says: Sep 6, 2011. 2:10 PM
really like that
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
