This bed cost me about $22. The only thing I bought new was the 2" x 8"s. I got all the slats (the crosspieces that support the mattress), the bolts, the pegs that hold the headboard together, and the mattress for free. Scrounge on!
If you add fasteners to the mix, expect to spend another fifteen bucks or so.
You will need these tools:
Drill
Impact driver (or make do with your drill)
Ratchet and socket set
Circular saw
Drill bits
Speed square
Pencil
Tape measure
You will need these materials:
5 2" x 8" x 8' yellow pine boards, straight as possible
5 2" x 6" x 8' yellow pine boards, salvage preferable
8 1/2" x 4" galvanized lag bolts
32 1/4" x 4" galvanized lag bolts
Wood glue
1 1/2" x 3' dowel
Remove these ads by
Signing UpStep 1Framin'
So, the long sides are one inch longer than the mattress, and the short sides are four inches longer than the mattress, to accommodate both one inch of play on the mattress and one and a half inches on either side to overlap and create the joint with the long sides.
To reinforce the corners and create a spot for the legs to attach, I put a brace in each corner that was made from one of the leftover scraps of 2" x 8". Just cut the biggest right triangle you can out of the material. Make four of those.
Lay out the box on a level surface.
I am not done with my own headboard, but when I do - I'll get a picture up.
Thank you soooo much for this, super fun and my introduction to using lag bolts has opened up a whole new world!
As to the height of the bed, that's all on purpose. I don't like those tall beds that always make me feel like I'm about to roll off. Guess that comes from so many years of sleeping on the floor.
They do make three inch, coarse-thread, phillips-head, standard black ssheetrock screws, got them from the Ace down the street. Maybe I forgot to mention, but I pre-drilled everything of course.
I don't want to cover the nice galvanized hex bolts with some ugly plastic button -- let the material be, it's beautiful as is.
Thanks for the comments, helps make everyone's projects better.
