Step 4X,Y,Z tables for your brunch
making the tables for the slides but once they are made it really feels like the project
is taking off.
Required Materials
Quantity Type Cost
1 6"x12"x1/4" Acrylic sheet Scrap
1 6"x10"1/4" Acrylic sheet Scrap
1 5 1/2"x5"x1/4" Acrylic sheet Scrap
15 1 1/2"x1 3/4"x1/2" Acrylic sheet Scrap
Now what you are going to want to do is stack 4 pieces of the 1 1/2"x1 3/4"x1/2"
and drill dead center with a 3/8 drill bit
After you have done so feed 2 pieces on each rod
and line them up and place your sheet on top and flip it over now glue.
Repeat for each axis
For your Y axis
now would be a good time to drill your holes so you can mount things you wish to cut.
UHMW is also almost twice the price of HDPE which for the person with the shallow pockets would really not appreciate.
I really do like everyone throwing out there ideas because this was an instructablefor someone to get an idea and develop my design into something that suits them or maybe if they want to spend a little more you could upgrade the material or purchase nice steppers. Whatever it maybe I wanted to show that 20 bucks and lots of searching time could make you something cool and possibly useful if you put the time into building it correctly.
That said, if you live somewhere with a constant (or complete lack of) humidity, such as in the desert somewhere, wood that has been fully cured (and/or fully weather-sealed) may work just fine. For anywhere else, I suppose if there were enough play between the wood parts and the rods, then you may be able to make it work with a sacrifice in quality of the finished product and the risk of binding up of the threaded rods and couplers.
If you aren't after high quality reproduction of your design (accuracy), then wood may be fine there, also. Basically, this is a M-16 vs. AK-47 argument. One has tighter tolerances and higher accuracy, and the other has looser tolerances and lower accuracy. In the end, if it is good enough to do the job, that is all that matters. Binding would be the only risk here.
In short, this all depends on how accurately you want to (and can!) measure the changes.
