3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$20 Charging Station
If you're reading this, you probably have enough electronic gadgets around the house to choke a small animal. This isn't the bad part. The bad part is the mess of wires and chargers that are strewn around the house and cluttering up tabletops and desk drawers. You can usually never find the charger you need or you don't use the device because it's never charged.
I've seen these Charger Valets online and at various stores, but they usually cost a small fortune and can't hold all the stuff I need. I've got to charge my cellphone, my wife's cell phone and Zen, the digital camera and my bluetooth headphones at the very least.
Step 1Supplies
I picked up a $13 leather-like box at Winners, a $2 plush brown face cloth and a couple of extension cords.
27 comments
Feb 9, 2008. 4:59 PMcojafoji says:
That entire project, while looking very nice and usable, screams fire hazard. Putting that many cords into a confined area surrounded be cardboard is NOT a good idea. With that, you are just begging for a short followed by a fire. A+ for idea, F for design.
Feb 9, 2008. 8:01 PMmikes80501 says:
The issue is zero airflow around the wall warts. Older ones will generate several watts of heat. It doesn't sound like much but if you pile several in an enclosed area, there can be a significant temperature rise. Newer wall warts are much less wasteful especially when nothing is hooked up. It wouldn't look as nice but if it was built out of metal, the metal would spread the heat around and also could not ignite. Wires could be threaded through a hole in the metal if you use a grommet to stop the wires from being cut by the edges of the metal hole.
Jul 20, 2009. 8:08 AMbrackforn says:
I am thinking about building one of these out of a metal toolbox so that it will be portable. It would have to accommodate several wall warts (iphone, two ipods, laptop, second cell phone), and I am really worried about the heat. Do you think it would be possible to install a fan to vent the thing when it was drawing power?
Jul 20, 2009. 9:10 AMmikes80501 says:
Since you are putting it in a metal box, you probably do not need a vent. Metal will get the heat out so much better than a wooden box. In line with other comments, feel the charger after it has been charging for a while to see if it feels particularly warm. A little warm is unavoidable. If you insist on a vent, be sure to have both an inlet and an outlet for airflow. To avoid it being noisy, get a large fan and run it slow. Alternately, you can make the whole thing vertical, put some vents in the bottom and the top and go with a chimney effect so the hot air draws itself out.
Jan 11, 2009. 5:29 AMmicromuffin says:
Not to be mean, but I could buy a factory-made charging station for $20. Maybe you could use cheaper materials?
Nov 3, 2008. 1:58 PMxboxteen01 says:
So I just started buying materials for my own charging station and the box im using is a wooden box. Any thoughts on how that might fare on the fire issue end? it has four 1/4" holes drilled in it for rope handles but im gonna take those out so i figure those will vent.
Feb 10, 2008. 2:56 PMpolar bear6 says:
damn, i just threw out my converse all star shoe box! it would have been super sweet for this thing :(
May 31, 2008. 10:51 PMDerin says:
i do not need a waf i need a g?ln?*
*g?ln?=geeky?looking nice?
Feb 15, 2008. 8:41 AMAnEngineersView says:
I caution you readers about building one of these ... its a fire hazard!! Think about it, chargers are designed to be connected to the wall and have air flow. If you stuff them in a box they WILL get hot and could start a fire.
How do you get around this?Take a look at one of these quad chargers that have four outputs built in from Gomadic here Quad Wall Charger ... or just buy one that includes the wall charger already like this one ... Gomadic Charging Station
It is common for people not to consider heat ... heat is the most common damaging element to electronics.
Cheers
May 31, 2008. 10:49 PMDerin says:
they will not overheat if you do not overload it
May 11, 2008. 6:31 PMmartymunch says:
This is way cool. And yeah you can spend $50 and get one from Gomadic but what fun is it to buy what everyone else has? Besides this is Instructables. I'M BUILDING ONE!!! fav'd
Feb 14, 2008. 12:12 PMgbosbiker says:
i dont really see the point in this. couldnt you just take an old shoe box and spray paint it and have the same effect for no cost??
Feb 12, 2008. 12:15 AMdragev says:
Nice idea if you don't think you'll ever need to take one of the charging cables on a trip.
Feb 10, 2008. 5:44 AMBrennn10 says:
This is pretty neat! It is one of those, "Why didn't I think of this?" Instructables. Nice job!
Feb 9, 2008. 10:49 PMStarBlades says:
oh wow im amazed at your creativity... i gotta do this..
Feb 9, 2008. 4:18 PMSDx says:
The main concern which has prevented me from constructing such a station, though I've wanted to, is that it seems like a potential fire hazard. Looks great though.
Feb 6, 2008. 6:30 PMLinuxH4x0r says:
Cool! I would recommend adding a switch for each charger (or one for all) to reduce wasted power, and I would use the top instead of cardboard.
Feb 6, 2008. 3:09 PMGorillazMiko says:
Very good idea and good Instructable too. Never would have thought of this, it just came out incredible. Hopefully I'll do this soon for my parents (maybe, I guess we don't really need it) but if I do then I'll do this for sure. Nice job.
Feb 6, 2008. 11:25 AMxboxteen01 says:
very cool idea and technique, i was meaning to make one and this looks great
Feb 6, 2008. 7:50 AMKozz says:
Simple and brilliant. I like it!!! A few improvements I could think of would be to cut a lengthwise slit perhaps 1/4" wide, with the hole at one end. You can pull the charger dongle through the hole and then slide the cord down the length of the slit, perhaps providing a better angle at which to connect the device to be charged. It could make it easier since most connectors aren't L-shaped, and you wouldn't have any stress on the dongle or charger port on the device because the cable is being pulled at an angle from the hole. Also, incorporating a small power strip would be nice, perhaps with the master power switch accessible. Using it could reduce wasted power consumed by unconnected AC adapters when no devices are charging. But of course you could always unplug the main extension cord, too -- easy enough if you remember. Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:SandyWalsh
