20-Gallon Aquaponics System With Arduino Monitoring
3,928
77
Published
Introduction: 20-Gallon Aquaponics System With Arduino Monitoring
We made a small system meant for classroom use. We wanted a multi-disciplinary project; this includes construction, biology, chemistry, and electrical.
Step 1: Gather Materials
Before you even start constructing your system you need to be aware of all the materials you have to work with. Our group was given a set of materials (see attached document for prices) that consisted of:
5- 5 Gallon Buckets
3/4" PVC 90 degree elbow (3 pack)
3/4" PVC 45 degree elbow (3 pack)
3/4" PVC Pipe 3 feet
3" PVC Pipe 3 feet
3/8" Clear Vinyl Tubing LENOX
1-1/4 1.25" Hole Saw
80 GPH Fountain Pump
PVC Cement and Primer
GROW!T Expanded Clay Pebbles
API Freshwater Master Test Kit
API Tapwater Conditioner
16oz Bottle Purina AquaMax
Fingerling Starter 300 Sinking Pellet 3lbs
Fish Feeder
Tubing Restrictor Clamp
Radish Seeds
Indoor Mechanical Timer
TaoTronics LED Grow Lightbulb
3/4" Uniseal Flexible Tank Adapter (5 pack)
25 ct aquarium bio balls
Waterproof Temperature Sensor
2 Arduino Uno
pH Sensor
Various Jumpers/ Alligator Clips
Step 2: Brainstorm Ideas
Our group remembered the constraints and started trying to plan accordingly. We knew we had 5 buckets to work with and we knew we needed a least 4 different compartments. We thought about what are system needed to focus on the most and that was the fish, the plants, and the filtration. We knew we needed exactly one bucket for the plants and two buckets for the filtration. Since we knew each of the tilapia fries needed 3 gallons we thought we might use 2 buckets to house them. With 2 five-gallon buckets, we felt we could appropriately house 4 fish. We thought we could also use the extra bucket to separate the bio balls and swirl filter.
Step 3: Create a Plan
After getting our actual materials that we were working with our designed changed a little. We also decided to consolidate the mesh filter and bio balls so that we could have an empty bucket for adding chemicals and monitoring the water. Our final system had water flowing from an elevated grow tray held up by an upside-support bucket. the bottom 3 buckets would be for the fish, the filtration bucket, and the monitored bucket.
Step 4: Begin Construction of the Bucket Portion
We first started by taking the handles off the buckets and then by cleaning some of the trim from the buckets. We removed the trim by slicing it off by combining a wood burner and an Exacto blade. We then lined up and marked the buckets by where we wanted to connect them. We used a string and a marker to guide an even cut around the grow tray bucket to make it shorter. Lastly we lined up our buckets for how the water would flow.
Step 5: Aid in Plumbing
In all the buckets, we inserted the uni-seals with an expanding lip design, to create a complete seal all the way around, as the pipes go through.
Step 6: Add Water to Test System
We began by adding water to the grow tank, testing the bottom seal to ensure that nothing leaked. Then as the seal was tested, we put water into the rest of the system to ensure the seals were tight and no water would flow outside.
Step 7: Began Work on the Grow Tray
We cut the 5-gallon bucket 5.5 inches from the bottom all the way around. We then attached the Media filter pipe an inch and a half from the edge. The media pipe is there to prevent any of the grow media from getting into our bell siphon area. We did not glue the media pipe down, however, we should have as we encountered a few issues with media getting into the pipe as we got it all settled in. The media pipe had lots of holes drilled into it, to allow ample water flow, but it's important to make sure the holes you drill are smaller than the media that you place into the grow tray.
Step 8: Construct Bell Siphon
In order to create the bell siphon, we used a 3" pipe (black) and 1" pipe (white) to create the suction. In order to see the process in action, we created an acrylic covering, that also functioned as the seal in order to get the Bell Siphon to activate. There were multiple holes drilled into the bottom two inches of the bell siphon to allow water to pass through, as well as a single extremely small hole, in case the system failed, it will drain out so the plants will not drown. We originally ran into some siphoning issues, getting it to activate and to stop, so we 3D printed a small funnel-like piece, that decreased the hole's radius to just half an inch in order to create more pressure inside the pipe, allowing for easier flow.
Step 9: Adjust Bell Siphon for System
While constructing our Bell Siphon, and after dozens of tests, we noticed an issue that there was too much pressure, so the siphon wouldn't "break", or reset to clear the siphon and begin filling it up again. To combat this, we drilled a hole at the top and attached an air tight tube, and ran it along the base of the pipe to the hole line near the bottom. This allows for more opportunities for air to enter the system and "break" the siphon. We experimented with adding cuts on the sides, however this just added air into the siphon system, but not enough to break the siphon. It added enough air to slow it down, but not enough to stop it.
Step 10: Prep System for Fish
Add seeds for plants and condition the water
Step 11: Add Fish
Add 2-3 fish depending on breed and size. There should be 3 gallons of water per inch of fish for the Tilapia fish we used, therefore, we only put two fish in our fish tank bucket.
After adding the fish we ended up needing modifications to the system to prevent the fish from jumping out. This will be explained further later on.
Step 12: Observe System
Keeping the system clean and making sure that roots and growth medium are not interfering with the bell siphon are key to making sure the system functions properly.
As we monitored our system and observed it we were constantly having to clean the roots and pebbles out of the bell siphoned as well as using a siphon vacuum aquarium cleaner to help when we did a water change.
Step 13: Make Adjustments to System
The major adjustment we had to make to our system was to add some type of cover to the fish tank part of our system to prevent the Tilapia from jumping out. We had one fish that insisted on trying to get out of the tank so we decided to put a wire cover over it and this was successful in preventing the fish from being able to get out.
Another minor adjustment was making sure the pipe that goes into the fish tank to fill it was tight so that it was not falling out and making sure there was something to filter the water coming out of the grow bed into the fish tank to prevent excess dirt particles from the growth medium from getting into the fish tank.
Step 14: Watch the Plants and Fish Grow
Over a few weeks, we had about 5-7 radishes grow and our 2 fish grew a decent amount given the amount of space they have and the conditions they are in.
For a beginners system, this was an extremely successful system and we learned a lot while we went through the process of building, troubleshooting, adjusting, and monitoring our system.
Step 15: Setup the Temperature Sensor
We had a 3-wire temperature sensor that we connected to an Arduino Uno. You can see the connections we made in the image above [black=GND, red=5V, yellow=DataPt], we also had to put a 4.7Kohm resistor in between data and 5V connection.
Step 16: Coding for the Temperature Probe
We found the code at this website. As soon as we uploaded the code we ran the Serial Monitor to find our sensor reading the temperature accurately.
Step 17: PH Sensor
After getting the water temp sensor working we then turned our attention to the pH sensor. After ordering it we saw that it came with instructions for how to put it together and the code for programming it. Here is what came with our sensor. After we programmed it we had to calibrate the sensor so it would read the pH right. Then we placed it into the tank with the fish.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    Great system. Do you have any idea how much electricity the system uses?
