This instructable seeks to significantly reduce the cost of silkscreening small numbers of shirts. For years I'd wanted to try it, but I couldn't justify the cost. Even the $100 screenprint "systems" seemed too expensive; what if I didn't like it? what if the quality was crap?
As far as DIY methods I found, nothing quite scratched my itch. Because I didn't know if this is something I would even like, I didn't want to have big picture frames or emulsion chemicals lying around. I wanted something I could neatly stow away and play with when I felt like it.
This is the instructable I wish I had found many years ago. The goal here is that you can walk into a fabric/craft store, spend about $20, and walk out with everything you need to make some decent-quality prints.
This procedure is basically a mashup of two other Instructables. The fabric-hoop idea I got from here, and the adhesive vinyl idea I got from here. I added a few tweaks, and the rest is history.
Step 1: Required Materials
Printout - An image of what you want to silkscreen, mirrored from how you want it on the shirt.
Adhesive Vinyl - You can probably get this cheaper online, but I wanted to use something that I could buy locally. I used this stuff, designed for the Cricut vinyl cutter. (~$10)
X-Acto Knife - If you have a vinyl cutter, by all means use it. I don't have one however, so I used an x-acto knife (~$2.50) to cut my pattern into the vinyl.
Sheer Fabric - I used an old window-curtain, but you can buy this stuff at any fabric store for $5 a yard. You're looking for a mesh that's open enough to allow the ink to go through, but tight enough for the vinyl to adhere. (I think this would work)
8" Fabric Hoop - This will hold the fabric taut. I got mine for $1.29
Scissors - For cutting the fabric and vinyl roll. you don't need anything fancy. I'm not adding this to the cost because if you don't have scissors, you should probably buy a pair to have anyway.
Masking Tape - Used for transferring the vinyl to the fabric, and for masking-off unused areas of screen. (~$2)
Pencil & Pen - These are for transferring our image to the vinyl.
Silkscreen Ink -This is probably the biggest variable in the kit. I was able to spend $4 on a 2oz bottle of ink. Depending on the selection at your craft store, you may need to spend more on a larger amount.
Scrap piece of cardboard - Used during the inking process as both a backing and a squeegee.
And that's it. Cheap! Some of this stuff you may already have. The rest you should be able to source locally. I'll be inking one item for this Instructable, but there is enough stuff here to make many more screens without needing to buy anything else.
Step 2: Transfer Pattern to the Vinyl
The first thing to be done is to get your image transferred on to the vinyl. For this I used a technique I learned in elementary school. It's a carbon transfer of sorts:
1. Use the pencil and draw fat lines behind your image.
2. Tape the paper to the vinyl, lead side down
3. With firm pressure, use the pen to trace your image. The pressure will push through the paper and transfer pencil to the vinyl wherever you draw.
NOTE: It's important to transfer the ENTIRE image. Writing this Instructable I realized that I forgot to copy the elements from robot's chest!
Step 3: Remove Areas to be Inked
Depending on the complexity of your design, this can be a tricky process. The wheels and hands of the robot gave me particular grief. Little bits kept pulling off, but I was able to stick them back in place after I had removed the unwanted vinyl.
Step 4: Prepare Fabric Screen
1. Put the fabric into the hoop and trim with scissors. Leave an inch or two of excess sticking out of the ring.
2. Adjust the ring tension so that it is snug, but not totally locked down.
3. Tug on the excess fabric wherever necessary to smooth out the fabric in the ring. Use your index fingers to stabilize the inner ring so it doesn't pull out.
4. Tighten down the hoop, and the fabric is ready.
Step 5: Transfer Vinyl to Fabric
when I say "the squeegee side" of the fabric, I'm talking about the side inside the ring (the one pictured in the previous step.) When I say "the shirt side" of the fabric, I'm talking about the other side. This is the side of the fabric that can be pressed onto the shirt without the ring getting into the way.
Got it? good. Let's get the vinyl onto the screen.
1. After cutting your vinyl pattern off of the roll, cover it in masking tape. This will keep the floating sections of vinyl in place during transfer.
2.Peel the adhesive backing off of of the vinyl, and LIGHTLY apply it to the shirt side of the fabric. The goal of this step is just to evenly apply the stencil, not to get good adhesion. That's what the next step is for.
3. Flip the ring so that the vinyl is on a hard surface. From the squeegee side, force the fabric into the vinyl. I used mainly the edge of my thumbnail with a lot of force. Pay extra attention to the small pieces of vinyl. We need them to want to stay on this fabric!
4. Back on the shirt side, slowly peel off the masking tape. If the vinyl starts to pull up in spots, try pulling the tape at a different angle or from a different direction. you can also get in there with the x-acto knife to keep the vinyl from sticking to the tape.
5. Just in case any vinyl was disturbed during tape removal, repeat #3 to get that vinyl nice and stuck to the fabric.
6. Lastly, use masking tape (on the shirt side) to cover up any remaining sections of fabric that you don't want ink going through.
Step 6: Ink
1. Put a piece of cardboard inside the shirt behind the area to be inked
2. Apply the screen, and put some ink in it.
3. Use a small piece of cardboard as a squeegee, getting ink through all the openings. Use your other hand to keep the stencil from moving during this process.
4. Using a hand on either side, slowly lift the stencil off the shirt.
Step 7: Cleanup
Step 8: And That's It!
Go for it! If you left for the store now, in a few hours you could be looking at a freshly-inked shirt. That YOU made.
Visit Our Store »
Go Pro Today »
thanks for sharing your ideas!
I may have mis-read though. do you have an instructable you could point me to?
http://www.instructables.com/id/Freehand-Acrylic-Painting-for-T-shirts/
http://www.instructables.com/id/Creating-a-T-Shirt-Logo/
I remember reading somewhere that the fabric medium was glycerine. Glycerine has been used in ink since ink was invented. It makes ink flow and prolongs the drying time. It does the same in acrylic paint.
Here are a few which suggest acrylic paint.
http://www.instructables.com/id/down-and-dirty-screenprinting-for-under-10/
http://www.instructables.com/id/Stencil-Shirts-with-Freezer-Paper/
http://www.instructables.com/id/Unorthodox-T-shirt-Printing-Stamping-T-shirts/
http://www.instructables.com/id/Summery-Neon-Stripe-Shirt-Upcycle/
I believe these are suggesting the use of artist acrylic paints from a hobby store. I'm suggesting it is much less expensive to get a quart of interior house paint from a hardware store. If you get white, you can mix the primary colors from the hobby store acrylics as you need it.
If you have ever painted a room and accidentally splattered latex (acrylic) paint on clothing, it NEVER comes out. If you get a big glob, it might crack later. If you get it on your clothes and try to wipe it off, it does not crack. That would tell me that if you don't go too thick with the paint from a screen print, it should not crack.
(main reason why i stay away from all these screen printing guides...)
the time it takes really depends on the complexity of the design and your skill with the knife. I'm not awesome or anything, and this robot design took about 2 hours. well inside the "few hours" I mentioned.
