3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
20 minute (?) stocking
A last minute stocking made from some scrap material I had. An extra holiday guest? Extra material? Extra 20 minutes? A Christmas eve quick stocking tutorial. Cheers & have a good holiday.
ps - you can see the full tutorial and others on my blog, www.thescienceofcraft.comwww.thescienceofcraft.com
Step 1Supplies
supplies
Well maybe 10 minutes if you had some holiday espresso, or 30 if you want to fuss with it a bit more and it takes a while to set up your sewing machine. First there’s the materials. I had this great green & teal upholstery material and this white material with a slight pattern in it. (The white material is a little thin so I added an extra later of a thicker felt-like material). I’ve also made a .pdf of a stocking pattern.pdf of a stocking pattern you can use (keep in mind the pattern’s letter sized for print, so your stocking will be on the small side. It scales fine though).
7 comments
Dec 19, 2010. 4:06 AMgranyhuskr says:
This is a fun project. I have started making stockings for all of my family using sentimental scraps or clothes. I used running t-shirts with pictures on them, clothings of deceased members and friends, etc. Anything that brings back good memories.
Nov 25, 2009. 4:16 PMsunshinegal says:
Hello
In what order do I put the cuff, lining , and the out side piece?
Nov 25, 2009. 4:00 PMsunshinegal says:
Hello
Step 2: Which way is the stocking and lining go? Do you put right side facing up then put lining down? Thank you
Nov 25, 2009. 3:38 PMsunshinegal says:
Hello
I was looking on your site for the stocking tutorial but I can not find it. What is it under ? Is it still there? www.thescienceofcraft.com Thank you Bethanne
Dec 24, 2007. 8:25 PMGorillazMiko says:
aha cool, looks easy. :D
Dec 24, 2007. 7:59 PMSunbanks says:
I think I will go make one of these because we never got anything but the Christmas tree and lights down from the rafters....
Dec 24, 2007. 7:53 PMWeissensteinburg says:
I don't think I've seen a more perfectly timed instructable yet. Just today, we realized that we accidentally threw away our stockings (which were in a garbage bag in the garage) Unfortunately, it's 11 o'clock, and there's no way we'll be able to make some. But still - Great instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:emma1181
