Introduction: 2000V Home Made/DIY Stun Gun
in this ibles u will learn how to make a some thing like a plastic baton+stun gun.
oh btw.....THIS IS ALL MY IDEA....I DID NOT STOLE IT FROM ANYWHERE...I SWEAR!!
Step 1: Get the Stuff
all u need is:
bug zapper thing
screwdriver
solder
wires
2 pin plug
files
vice grips
heatshrink tubing
keeping/twisting thing(see pic)
some knowledge about electronics and common sense
IMPORTANT
all the stuff i use is legal....especially the bug zapper, which is rarely illegal in any country....even in my country.....where guns,swords,combat knives,explosives,pepper spray,stun guns,hand cuffs,thumb cuffs,leg cuffs,high powered lasers,airsoft guns lighter shaped like guns/pistols,real guns,live rounds,contraband cigarettes,drugs are ILLEGAL in my country....i live in the safest place ever.....on a mountain....lol ....i actually live in SINGAPORE.....oh ya btw....my country just turned 44 yesterday :)
HAPPY BIRTHDAY SINGAPORE!!!
bug zapper thing
screwdriver
solder
wires
2 pin plug
files
vice grips
heatshrink tubing
IMPORTANT
Step 2: Open'em Up
locate all the screws and unscrewthem
NOTE: some screws may be under a sticker
nce u opened it , u will see a circut board
IMPORTANT!!:"short" out the circuit before touching!!
keep everything! the 5 screws and the button in the other half of the handle
Step 3: Get the Ugly Crap Out
next,pry open the tennis/badminton head out...u should end up with just the handle part.
u should end up with the parts that are not needed
Step 4: Make the Cool, Scary Tip
next, we wanna make the tip that scares most friends....using the 2pin plug
Step 5: Make Way!
first, file/cut/dremel in between the 2 pins so that u can screw it on later
Step 6: Scary Stuff
next, bend the 2 pin s together.......u will probably be left wit some cracks....it's just fine!....next, get ur self some of the wire keeping/twisting thing(see pic) and get the metal
coil it around one of the 2 pin plug,making sure it's in contact with the pin u coiled around
next get another keeping/twisting thing(see pic) and some heat shrink tubing
poke a hole in 1/3 way through of the heat shrink (only 1 hole needed)
get the coiled keeping/twisting thing(see pic) and put it on the 2 pin plug....then put on the heat shrink,making sure it it sticks out throught the little hole u made earlier
next, add heat!
THE SCARY TIP IS DONE!!!:)
next, add heat!
Step 7: Gonna Finish
next....just solder all the wires.....
the red wire on the circuit board - any one of the 2 pin plug
x2(black wire) on circuit board... - use only 1 of the 2 wires and solder to the other side of the 2 pin plug (using 2 black wires would be saferthought.....if some how 1 cable has problems)
MAKE SURE U PUT HEAT SHRINK TUBING SO THAT NOTHING SHORTS OUT ITSELF
Step 8: Assembly
put everything back in and ....SUDDENLY it does'nt fit......then, get a jet lighter or some small torch and a big diameter screwdriver which cannot fit the screwhole on the assembly
light ur...lighter while pressing down the screwhole part of the whole assembly
this will melt the plastic into a sort-of L-shape
Step 9: Done....sort Of
once u screwed everything.....all u have to do now is test it out.....
BUT before u do that, u have to re-position the keeping/twisting thing so that it arcs to one of the 2 pin plug
don't put the keeping/twisting thing too close......u want it to arc every1 sec if the button is held down continuously
Step 10: I Applaud You
u have just made a home made stun gun....NOT taser�"....... taser" is a brand!!
Step 11: ATTENTION!!
please do not test this great creation of mine on an animal.....it will hate u forever...lol
btw if u wanna test it on someone.....be sure that they allow u to stun them......if not ......it's just rude........i mean...u wouldn't like someone stunning u when u're drinking beer or doing ur work.....i would grab that thing and stun him back.....
Step 12: Word of Advice
after each use, by which i mean scaring them with the electric arc.....be sure to discharge the thing or it still can stun ppl.....
Step 13: Voltage
wanna check how much volts urs is gonna produce?
no prob....just take a look at a brown component on the circut board and read the printing
