2008 GMC Yukon Aftermarket LED Tail Light Installation Guide
125
Posted in WorkshopCars
Introduction: 2008 GMC Yukon Aftermarket LED Tail Light Installation Guide
About: Everything about automotive LED lights
This installation guide will show you how to install a pair of LED tail lights for the 2008 GMC Yukon. You will find that installation will be quick and straightforward. After installation, your GMC SUV will be much more visible from its back end.
Step 1: Remove the OEM Tail Lights.
Use a screwdriver to safely separate the tail light from the chassis. Disconnect the stock harnesses from the tail lamp.
Step 2: Attach a Resistor Box to the LED Tail Light Assembly.
If you have a resistor box to prevent hyperflashing, attach it to the body of the LED turn signals and connect the wires.
Step 3: Connect the Wires to the LED Tail Light.
Once you connect the stock harness to the resistor box wires, test the tail light assembly to make sure it functions as intended. Once you've confirmed that it does, screw in the LED tail lights to finish up.
Your GMC Yukon is now equipped with an LED turn signal tail light set!
Shop for more car LED aftermarket tail lights at store.iJDMTOY.com today!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
