2/3 EDIT AND CREATE BLOCK IN ARDUBLOCK 2/3
1,945
14
Posted in TechnologyArduino
Introduction: 2/3 EDIT AND CREATE BLOCK IN ARDUBLOCK 2/3
PART 2/3
EDIT ARDUBLOCK (second way)
THE SERIOUS WAY
drag and drop out Partie_Emetteur.class ( ardublock-beta-20140828.jar\com\ardublock\translator\block\Duinoedu )
Upload the Partie_Emetteur.class on java decompliler http://www.javadecompilers.com
(posssible you can do the same work with jad command .I have not tryied it)
Download the file and extract (take only Partie_Emetteur.java)
Open Partie_Emetteur.java with java editor
Play with the code and save it (it's simple)
Now its intresting
download the SOURCE CODE of ardublock
https://github.com/taweili/ardublock
https://github.com/taweili/openblocks
You must have ardublock-master.zip and openblocks-master.zip
Make TWO folder ONE with the name ardublocktemp on disk C:\ARDUBLOCKTEMP\
and onother C:\ARDUBLOCK
Drag and drop the ardublock-master and openblock-master.zip in ardublocktemp
extract both in C\ARDUBLOCKTEMP\
Copy folder EDU from openblock C:\ARDUBLOCKTEMP\openblocks-master\src\main\java to C:\ARDUBLOCK\
Copy folder COM from ardublock-master C:\ARDUBLOCKTEMP\ardublock-master\src\main\java to C:\ARDUBLOCK\
Copy the Partie_Emetteur.java to C:\ARDUBLOCK\
You must have in folder C:\ARDUBLOCK\ edu , com folder and Partie_Emetteur.java
close all
Open dos command go to C:\ARDUBLOCK and type javac Partie_Emetteur.java . Convert java to class
close dos command and open ce2.23 class editor
Load the new file Partie_Emetteur.class from C:\ARDUBLOCK\Partie_Emetteur.CLASS
Modify on (up and right) button
In square version and under MAGIC NUMBER there is "Major Version 51" CHANGE to "Major Version 49"
In square Property Change "Accept" push button . SAVE and exit.
Push back the new class file to ardublock.jar
Finished the second way (correct way).
Step 1:
THE SIRIOUS WAY
drag and drop out Partie_Emetteur.class ( ardublock-beta-20140828.jar\com\ardublock\translator\block\Duinoedu ) Upload the Partie_Emetteur.class on java decompliler http://www.javadecompilers.com
(posssible you can do the same work with jad command .I dont have try it)
Open Partie_Emetteur.java with java editor Play with the code and save it (it's simple)
Step 2:
Now its intresting
download the SOURCE CODE of ardublock https://github.com/taweili/ardublock
Make TWO folder ONE with the name ardublocktemp on disk C:\ARDUBLOCKTEMP\ and onother C:\ARDUBLOCK Drag and drop the ardublock-master and openblock-master.zip in ardublocktemp extract both in C\ARDUBLOCKTEMP\
Copy folder EDU from openblock C:\ARDUBLOCKTEMP\openblocks-master\src\main\java to C:\ARDUBLOCK\ Copy folder COM from ardublock-master C:\ARDUBLOCKTEMP\ardublock-master\src\main\java to C:\ARDUBLOCK\ Copy the Partie_Emetteur.java to C:\ARDUBLOCK\ You must have in folder C:\ARDUBLOCK\ edu , com folder and Partie_Emetteur.java
Step 3:
close all
Close dos command and open ce2.23 class editor
Load the new file Partie_Emetteur.class from C:\ARDUBLOCK\Partie_Emetteur.CLASS Modify on (up and right) button
Step 4:
In squere version and under MAGIC NUMBER there is "Major Version 51" CHANGE to "Major Version 49"
In squere Property Change "Accept" push button . SAVE and exit.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
