well before we begin i must state a few things...
-PVC can only be used at half or less than half the pressure rating stamped on the pipe when pressurized gases are used in the pipe
-i would suggest never pressurizing this cannon above 150 psi, remember its only plastic
-never store any type of PVC pneumatic with pressure still in it
-always allow a full 24hours for PVC glue to dry before pressurizing
-when building pneumatics always use metal or PVC pipe (never ABS)
-PVC is shock sensitive meaning if its dropped on a hard its very likely it will be damaged and it would be very dangerous to pressurize after damaged
-PVC becomes very brittle below 32 degrees (Fahrenheit) and is very likely to explode if pressured in such conditions
-when building pneumatics pressure rated pipe should always be used (none of that cell core or DWV crap)
-the most important part of any pneumatic are the PVC welds AND I HIGHLY SUGGEST YOU READ THIS TUTORIAL before you even think about starting this.
-when you are dealing with high velocity projectiles always remember you safety glasses
-always be sure of your back stop when shooting any form of rifle, pistol, gun, bow.... anything that can fire some vague form of projectile
-and use common sense!
-do not use un-regulated HPA or CO2 in a PVC cannon ever they are stored at to high of pressures to be safe in PVC, but if you have a properly regulated setup they can be used ( if you lower the pressure to about 100psi)
Now onto the good part...
this is my entry for the launch it challenge, it is a 25MM Pneumatic Cannon. it has 2.5 foot long one inch diameter barrel with a custom bolt action mechinism, of course we have the 3-9X40 sniper scope, and a 1" modified sprinkler valve as the primary firing valve.
The Video...
invalid movie: http://youtube.com
remember always wear safety goggles, you never know where or when something will ricochet especially when its traveling at 300+FPS
Fun Fact: PVC shards can't be picked up by X-Rays (this is a safety tip! don't rush or you'll get a PVC shard in you and you probably wont get it out. im not saying you should sneak one of these into your luggage and go threw airport security. it would be way to big any way)
better video coming soon
If you like this instructable please register and vote for it in the launch it challenge (by click the plus icon next to the title)
DETAILED SPECS
power source------------------compressed air
power source pressure-----100psi
chamber volume--------------45 ci (approx.)
barrel volume------------------25 ci (approx.)
c/b ratio--------------------------1.8 to 1(approx.)
firing valve----------------------pneumatically actuated sprinkler valve (a "modded sprinkler" valve)
pilot valve-----------------------blow gun valve
fill valve--------------------------female quick disconnect
fire rate--------------------------single shot, bolt action
caliber---------------------------25MM ( one inch)
projectile velocity-------------unknown (coming soon)
effective range----------------unknown (coming soon)
maximum range-------------unknown (coming soon)
optics---------------------------3-9X40MM rifle scope
primary material used------PVC pipe
I WOULD SUGGEST YOU DO SOME RESEARCH BEFORE UNDER TAKING THIS PROJECT, LOOK INTO THE DIFFERENT TYPES OF PIPE AND THERE RATINGS, HOW TO SOLVENT WELD PVC (THIS IS A MUST), HOW TO PROPERLY DRILL AND THREAD HOLES FOR FITTINGS, THE TYPE OF CONDITIONS PVC CAN BE USED AND STORED IN. THE MAJORITY OF THIS INFORMATION IS CONTAINED WITHIN THIS INSTRUCTABLE BUT IT IS BECOMING CLEAR THAT MANY OF YOU ARE NOT READING ALL OF IT. I HAVE ONE FINAL SUGGESTION BUILT A BASIC PNEUMATIC OR COMBUSTION FIRST IF A BASIC CANNON FAILS IT WILL BE LESS DANGEROUS
PS - DON'T ATTEMPT THIS AT ALL IF YOU HAVE NO COMMON SENSE OR A LOW IQ
Remove these ads by
Signing UpStep 1The Parts...
Parts...
( 1x ) 2" PVC cap
( 1x ) 2" PVC coupling
( 1x ) 2" to 1" PVC bushing
( 2x ) 1.5" PVC couplings
( 2x ) 1.5" to 1" PVC bushings
( 1x ) 1" PVC tee
( 2x ) 1" PVC 90 degree elbows
( 2x ) 1" PVC male threaded adapters
( 1x ) 1" to .75" bushing
( 1x ) .75" PVC cap
( 1x ) .75" PVC tee
( 3x ) .75" PVC 45 degree elbows
( 2x ) .75" PVC 90 degree elbows
( 1x ) female quick disconnect 1/4"
( 2x ) 3/8" by 1/4" compression fittings
( 1x ) blowgun valve
( 1x ) 1" sprinkler vlave
a few inches of 1/4" ID flexible tubbing
assorted bits of 2", 1.5", 1", and .75" pipe
Tools...
a dremel
a band saw
a drill (preferably a drill press)
PVC primer (make sure its primer and not cleaner or it could end badly)
PVC glue
This is a fun instructable and I don't believe the accuracy of what you speak of here is required.
So the owner of this instructables use of the term of 'rifle' is more than acceptable.
Fabio Junio Dutra
but judging from the date of your comment, i guess you may have already made one diy airgun for yourself....
You can find them in several home improvement stores and wherever they sell irrigation products.
but that would be a very good idea if you were using the gun away from an aircompressor... infact i might try that
How does the trigger open the sprinkler valve?
boombox_654@hotmail.com grasias
great tutorial btw....i give it a 9.5/10!!
