3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
25MM Pneumatic Sniper Rifle
***Disclaimer*** The following is for informational purposes only, i take no responsibility for what you do with this knowledge. i can not be held responsible for any property or medical damages caused by this weapon. i would advise you to check your local laws. These types of guns are illegal in some areas, and i would highly advise you against building one of these in said areas. Pneumatic rifles can be very powerful and should never be pointed at a person or animal. Lastly when dealing with pneumatics never over pressurize them and always use NFS-PW pipe (as apposed to DWV)
well before we begin i must state a few things...
-PVC can only be used at half or less than half the pressure rating stamped on the pipe when pressurized gases are used in the pipe
-i would suggest never pressurizing this cannon above 150 psi, remember its only plastic
-never store any type of PVC pneumatic with pressure still in it
-always allow a full 24hours for PVC glue to dry before pressurizing
-when building pneumatics always use metal or PVC pipe (never ABS)
-PVC is shock sensitive meaning if its dropped on a hard its very likely it will be damaged and it would be very dangerous to pressurize after damaged
-PVC becomes very brittle below 32 degrees (Fahrenheit) and is very likely to explode if pressured in such conditions
-when building pneumatics pressure rated pipe should always be used (none of that cell core or DWV crap)
-the most important part of any pneumatic are the PVC welds AND I HIGHLY SUGGEST YOU READ THIS TUTORIAL before you even think about starting this.
-when you are dealing with high velocity projectiles always remember you safety glasses
-always be sure of your back stop when shooting any form of rifle, pistol, gun, bow.... anything that can fire some vague form of projectile
-and use common sense!
-do not use un-regulated HPA or CO2 in a PVC cannon ever they are stored at to high of pressures to be safe in PVC, but if you have a properly regulated setup they can be used ( if you lower the pressure to about 100psi)
Now onto the good part...
this is my entry for the launch it challenge, it is a 25MM Pneumatic Cannon. it has 2.5 foot long one inch diameter barrel with a custom bolt action mechinism, of course we have the 3-9X40 sniper scope, and a 1" modified sprinkler valve as the primary firing valve.
The Video...
Video
invalid movie: http://youtube.com
remember always wear safety goggles, you never know where or when something will ricochet especially when its traveling at 300+FPS
Fun Fact: PVC shards can't be picked up by X-Rays (this is a safety tip! don't rush or you'll get a PVC shard in you and you probably wont get it out. im not saying you should sneak one of these into your luggage and go threw airport security. it would be way to big any way)
better video coming soon
If you like this instructable please register and vote for it in the launch it challenge (by click the plus icon next to the title)
DETAILED SPECS
power source------------------compressed air
power source pressure-----100psi
chamber volume--------------45 ci (approx.)
barrel volume------------------25 ci (approx.)
c/b ratio--------------------------1.8 to 1(approx.)
firing valve----------------------pneumatically actuated sprinkler valve (a "modded sprinkler" valve)
pilot valve-----------------------blow gun valve
fill valve--------------------------female quick disconnect
fire rate--------------------------single shot, bolt action
caliber---------------------------25MM ( one inch)
projectile velocity-------------unknown (coming soon)
effective range----------------unknown (coming soon)
maximum range-------------unknown (coming soon)
optics---------------------------3-9X40MM rifle scope
primary material used------PVC pipe
I WOULD SUGGEST YOU DO SOME RESEARCH BEFORE UNDER TAKING THIS PROJECT, LOOK INTO THE DIFFERENT TYPES OF PIPE AND THERE RATINGS, HOW TO SOLVENT WELD PVC (THIS IS A MUST), HOW TO PROPERLY DRILL AND THREAD HOLES FOR FITTINGS, THE TYPE OF CONDITIONS PVC CAN BE USED AND STORED IN. THE MAJORITY OF THIS INFORMATION IS CONTAINED WITHIN THIS INSTRUCTABLE BUT IT IS BECOMING CLEAR THAT MANY OF YOU ARE NOT READING ALL OF IT. I HAVE ONE FINAL SUGGESTION BUILT A BASIC PNEUMATIC OR COMBUSTION FIRST IF A BASIC CANNON FAILS IT WILL BE LESS DANGEROUS
PS - DON'T ATTEMPT THIS AT ALL IF YOU HAVE NO COMMON SENSE OR A LOW IQ
Step 1The Parts...
The Parts...
we will be making this particular pneumatic out of mostly PVC so it is relatively inexpensive to make. here is what your going to need.
Parts...
( 1x ) 2" PVC cap
( 1x ) 2" PVC coupling
( 1x ) 2" to 1" PVC bushing
( 2x ) 1.5" PVC couplings
( 2x ) 1.5" to 1" PVC bushings
( 1x ) 1" PVC tee
( 2x ) 1" PVC 90 degree elbows
( 2x ) 1" PVC male threaded adapters
( 1x ) 1" to .75" bushing
( 1x ) .75" PVC cap
( 1x ) .75" PVC tee
( 3x ) .75" PVC 45 degree elbows
( 2x ) .75" PVC 90 degree elbows
( 1x ) female quick disconnect 1/4"
( 2x ) 3/8" by 1/4" compression fittings
( 1x ) blowgun valve
( 1x ) 1" sprinkler vlave
a few inches of 1/4" ID flexible tubbing
assorted bits of 2", 1.5", 1", and .75" pipe
Tools...
a dremel
a band saw
a drill (preferably a drill press)
PVC primer (make sure its primer and not cleaner or it could end badly)
PVC glue
950 comments
1-40 of 950next »
Apr 10, 2012. 5:07 AMbatonas says:
(removed by author or community request)
May 11, 2012. 11:49 AMjumpup_dnb_dj says:
The term 'rifle' is not meant to be taken in the literal sense. The term 'rifle' has been used to describe a variety of weapons that use a stock and is to be shouldered before one fires it.
This is a fun instructable and I don't believe the accuracy of what you speak of here is required.
So the owner of this instructables use of the term of 'rifle' is more than acceptable.
Apr 9, 2012. 10:07 AMZach the Man says:
and is it only one shot?
Apr 9, 2012. 10:06 AMZach the Man says:
i think my jaw just fell off my face when i saw that thing
Mar 12, 2012. 5:55 AMfjdutra says:
Well, to get where I find this valve and how it would be worth it if I send him the money and buy a pro Brazil send me inside mines can give me an answer on my imail fjdutra@r7.com required urgent thank you for comprehension
Fabio Junio Dutra
Mar 4, 2012. 3:47 PMMadBomber12 says:
This is ganna sound stupid, but what's the best ammo for this rifle?
Feb 4, 2012. 12:58 AMlewster says:
This is incredible! Have u thought about using paintballs or splatballs (from kmart) and a 15mm barrel to shoot them? This could be used with a spring feed, or just bolt action, for an incredibly awesome paintball gun! i have another air cannon (i lie, i have 3) and splatballs work great! u get them from kmart, or maybe walmart if ur in America?
Feb 6, 2012. 1:16 AMdog digger says:
In america, you can get proper paintballs anyway
Feb 7, 2012. 3:10 AMlewster says:
I KNEW THAT!
Nov 2, 2011. 5:54 AMlolzprox says:
Hey anyone know where to get that sprinkler valve? And the blowgun valve.. I live in Singapore, which none of the DIY stores sell such stuff. And any idea if i can replace the sprinkler valve with ball valve?? Thanks.
Feb 2, 2012. 3:01 AMde0509 says:
haha hello there, im from your neighbouring country. yeah, ball valves work fine too if we cant find those QEV stuff. mine uses a ball valve too. its less complicated but it still is fun.
but judging from the date of your comment, i guess you may have already made one diy airgun for yourself....
Nov 4, 2011. 4:26 PMdog digger says:
A ball valve will work fine. You just have to open it faster :)
Oct 20, 2011. 6:39 AMdeqwer says:
is there any chance that the air gun can shoot twice?
Feb 2, 2012. 2:58 AMde0509 says:
i dont think it can be done with just one valve.
Dec 9, 2011. 1:39 PMpopcannon says:
this may be a thick comment but where can i get the sprinkler valve and is "sprinkler valve" its real name?
Jan 8, 2012. 6:38 PMmonkhm says:
Check out spudtech.com, they are expensive but do the hard work for you
Dec 20, 2011. 2:34 PMacaz93 says:
it is the actual name, in fact, you can find them in many stores as "solenoid valves".
You can find them in several home improvement stores and wherever they sell irrigation products.
Dec 12, 2011. 10:12 AMjfsimalesg says:
RIFLE FOR PORTIONS OF THAT HAPPENS THE AIR ??????????????
Dec 9, 2011. 6:27 PMltran7 says:
I can't find 1" anywhere what can I do??
Nov 19, 2009. 11:27 PMfr05ty911 says:
instead of gluing the chamber in could you use a quick disconnect so you wouldn't have to keep refilling it and just swap chambers???
Jan 2, 2010. 12:24 PMdjzadjza says:
thats a god idea but the disconnect might be two small so you would have to use some reducers.
but that would be a very good idea if you were using the gun away from an aircompressor... infact i might try that
Dec 9, 2011. 1:54 PMpopcannon says:
maybe u could hav a hwhole second tank with a female disconect at one end and a male discnnect at the other, so u could fill it at the commpresser and then when u wanted to use the cannon away from the commpresser u could fill from that
Aug 28, 2011. 12:12 PMdeobomb says:
yeah you could make it snap on and off to make a fast change air tank
Nov 20, 2011. 6:39 PMshaclonts says:
Wouldn't that not work because the whole idea of the compression chamber is to quickly release the air? If you could do it that way you might as well keep it attached to the compressor and forgo making the compression chamber altogether.
Nov 8, 2011. 10:43 PMstevenh429 says:
Does it matter if your blow gun is rated at like 90 psi and you want to shoot at 100+?
Sep 20, 2011. 11:47 AMpenguinparty123 says:
this would be better if it had a trigger
Aug 26, 2011. 8:08 PMdeobomb says:
would it work to just run air hose from the tank to the triger and from there to the back of the barrel instead of useing the valve?
Oct 11, 2007. 1:56 PMmrfuzz says:
When you fire the gun won't the compressed air just leek out of the breech loader?
Dec 31, 2009. 8:32 AMCountry dude says:
couldn't you improve the preformance by sanding down the end of the barrel smooth (the end inside the bolt), then were the barrel meats the back of the bolt assembly you could put an O ring in there. in tern would stop a fair bit of air from coming out
Aug 23, 2011. 6:07 PMamenard1 says:
I simple used some duct tape. It probably doesnt do as good of a job as an o ring but it does help seal it.
Jun 10, 2011. 11:21 AMblubberdubber says:
Where can I get all the materials needed for this in the UK? I can't find PVC in particular.
Aug 16, 2011. 2:15 PMjaddis2 says:
what part
Aug 16, 2011. 2:14 PMjaddis2 says:
hello love the gun just wanted to know on the video what did you use to put the air in the gun what your friend used p,ease please could you tell me
Aug 10, 2011. 8:17 PMamenard1 says:
Will any sprinkler valve work?
How does the trigger open the sprinkler valve?
Mar 5, 2009. 2:49 AMuzairsagitarian says:
HELP! HELP! HELP! HELP! QUESTION: I have found in my local market (PAKISTAN) the pipes with following ratings (PVC 1" SCH 40 PSI 450 ASTM D-1785) and (PVC 2" SCH 40 PSI 280 ASTM D-1785) Does that mean that they have pressure ratings of 450 and 280 PSI respectively? Help would be really appreciated
Aug 10, 2011. 7:29 PMamenard1 says:
That is correct.
Jul 25, 2011. 10:37 AMandy panda says:
cuanto mide tu arma en realidad gracias por tu idea
Jul 21, 2011. 3:29 PMrafitaking says:
ola soy rafa hoye ke buen tutorial pero no se donde consegir una valvula si en mexico me podrias desir donde la consigo y cuanto cuesta mi email es
boombox_654@hotmail.com grasias
Jul 9, 2011. 2:21 PMAutoRifle12 says:
Ok, my sprinkler valve didnt have the hole at the top, it just has the hole to the left....will that change on how to mod works or do i need to do the mod different?
great tutorial btw....i give it a 9.5/10!!
1-40 of 950next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
86
Author:irwinner
