Step 2The Chamber...
The chamber in a pneumatic cannon is a buffer zone between the valve and the bike pump/ compressor. It allows a large amount of air to be stored and exhausted very quickly when fired.
this is my chamber, it is a 12 inch long piece of 2" PVC pipe with a 2" cap on one side and a 2" coupling on the other, attached to the 2" coupling is a 2" to 1" reducing bushing. After the chamber was glued i let it sit for an hour (so the glue could partially cure) then i drilled a 1/2" hole in the side of the 2" cap so i could thread in the brass quick disconnect. do not use any Teflon tape on this fitting, if it starts leaking put some epoxy putty or JB weld on the section where the threads meet the chamber.
but that would be a very good idea if you were using the gun away from an aircompressor... infact i might try that
