Step 3Gun Body...
first cut a piece of PVC double the length of a 1" socket and glue it into one of the 1" PVC elbows. then insert a a long piece of 1" pipe into the 1" elbow and the 1" tee( but don't glue it) this will help you get the joint between the 1" elbow and 1" tee perfectly straight. now glue the short piece of pipe sticking out of the the 1" elbow into the base of the 1" tee, use the long pieces of pipe to make the joint as straight as possible or the barrel will be off to the left or right of the gun. next is a rather odd step listen closely, i want you to glue the outside of the 3/4" end cap into the the back of the 1" tee. there are two things you want to remember here not all end caps will work do a dry test before you glue it and this is the part where the stock is connected to the body so make sure you insert the cap the right way (so the socket part is facing outwards making it possible to insert a piece of 3/4" pipe). next cut 7" piece of 1" pipe and glue it into the remaining socket of the 1" elbow.now cut a short piece of pipe and connect one of the male adapters to the remaining socket of the 1" Tee. the last piece your going to need a dremel for you need to modify one of the 1" 90 degree elbows to it can slid along a 1" piece of pipe relatively easy. sadly there is no trick to doing this your just going to need to take of a little material at a time until you get it just right. once the elbow has been modified glue the 1" to 3/4" reducing bushing into its unmodified socket then slide it onto the 7" long piece of pipe which is now glued in place. then glue the other side of the 7" long pipe to the chamber. you have now finished the body of the gun.
10
comments
Add Comment
Add Comment
