Step 4The Stock and The Valve
onto the valve, my valve is an orbit jar top that i have modded. normally it would be triggered by an electronic pulse but this does not allow the valve to open quickly so i modified to to run completely pneumatically , there are many tutorials on how to do this for example here is one here is another. if you cant figure out how to mod the valve i suppose you can buy one from here, i know the guy who runs that place hes not going to scam you and his work is very good quality. anyway to install a sprinkler valve on this particular cannon aply a good amount of Teflon tape to the 1" threaded adapter then remove the top of the valve and screw on the valve itself.then go ahead and put back on the top. do not put on the blowgun as of yet.
side note: be sure to put the sprinkler valve on the right way, becuase it will only work in one direction. there should be an arrow some where on it indication the direction of flow, remember the air is going to be flowing from the chamber to the barrel
great tutorial btw....i give it a 9.5/10!!
like a old pro, said read the all the paper before makn a comment
