2D Image to 3D Print
73,023
52
6
Posted
Introduction: 2D Image to 3D Print
Have access to a 3D printer and an image you want to print but no way to get it into fruition?
I'm going to show you how to take a 2D logo and make it into a 3D one using SketchUp.
Step 1: SketchUp and Plugins
If you already haven't you need to download Sketchup from http://www.sketchup.com.
From there you will need to download a plugin called SketchUp STL from this site http://extensions.sketchup.com/en/content/sketchup-stl.
To install this plugin launch SketchUp and open the SketchUp Preferences. In that side bar there is an Extensions option. Click on that and choose the Install Extension Button. It may ask you if you trust this plug-in. Choose yes.
Step 2: Now We Are Ready to Get Started!
Now we need to import your image.
This works best if you are using a JPG or TIFF extension.
Choose File -> Import
Choose your image.
Step 3: Start Creating the 3D File
After you have your logo imported, the next step is to trace the logo using the line and arc tools.
This is a long and tedious process. Don't give up hope, your almost there!
Step 4: Checking for Holes
After you have everything traced, if you did it properly you should see that some of the spaces filled in. If they did not you may have a hole somewhere. You may have to look a little close to find it.
One trick I found that helps is drawing a line between the part that is supposed to be filled in. If it doesn't fill both sides you have a hole.
Step 5: 2D to 3D in SketchUp
At this point you can remove the image from SketchUp. Now we have a drawn out 2D graphic.
Use this Push/Pull tool to raise/lower parts of your image.
You can even add a base if you wish by making a square under your drawing.
I made these as a medallion for a few friends that were leaving our HackerSpace.
Step 6: Making a STL File
Your almost ready to print!
Choose File -> Export STL
Choose yes when it asks to export the entire module.
Depending on the complexity, we now need to repair the file with NetFabb.
Upload your file to http://cloud.netfabb.com. They will repair the file for you. After a few minutes you should receive an email with a download link to the repaired file.
Step 7: Congratulations!
You now have a working STL file!
Send your file to http://www.shapeways.com or to your 3D Printer!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    Hi
    I want to design and send a 3D wall/door plaque from a photo. I live in thailand is it possible to use shapeway as a facilitator and if so can I just send them a photo?
    I really need help from the beginning as I don't know much at all.
    I don't know if I need a laptop or a desktop
    .sounds ridiculous I know but its true.
    I'm prepared to buy a computer on your advice.
    I really hope you can help
    Kind regards paul
    As far as I know the best tool for doing this is www.selva3d.com.
    It's done only in a single step, without need to download any software and it's free
    Has anyone figured out how to transfer a printed circuit layout, from a magazine or book onto a copper clad board using the 3D printer? It seems a single good base layer of PLA would leave the board ready to etch.
    I'd suggest if you have access to Adobe Illustrator to use the auto trave functions, tweak you setting, export an AI file, import into Sketchup and extrude. I'm confident that for high controst artwork there will also be free tracing tools available online.
