Introduction: 2D and 3D Tangram Puzzle
This is how to create your own tangram puzzle which can be used to create both 2D and 3D objects.
Step 1: What You Need to Get Started
Materials needed:
1 x A3 Masonite Board 3.2 mm thickness.
Tools needed:
1 x Laser Cutter on 80% power.
Image of Laser Cutter:
http://www.engravingmachinesite.com
Accessed on 29/08/2012
Step 2: Cutting the Tangram
Send the file as a PDF/CDR format to the Laser Cutting machine and cut it on the masonite board.
Step 3: Assembling the Container
Step 1: Remove the container pieces from the cut-out.
Step 2: Fit the side panels on to the bottom panel ensuring that the there is one.
Step 3: Locate the lid on top of the sides of the container.
Step 4: Making a 2D Object
Place tangram puzzle pieces on a flat surface to create shapes from the geometric puzzle pieces, make sure that the pieces do not overlap, but rather that the edges are side by side.
Step 5: Creating 3D Objects
Use the slots in the 2D pieces to press-fit into one another, ensure that you do not force the pieces together, the pieces will support each other on a 3D scale.
Step 6: Packing Away the Tangram
The Tangram pieces:
2 x Large Triangles.
1 x Medium Traiangle.
2 x Small Triangles.
1 x Parallelogram.
1 x Square.
There are 5 sets of each of the pieces mentioned above.
The sets stack on top of each other in the manner shown in the image below.
