2L Bottle Multi-use Container by wiley coyote
While cutting up 2L bottles for hydroponics planters, I found that they are of slightly different diameters and Pepsi bottles slide inside Coke bottles, when the ends are cut off. The flares at each end of the Pepsi bottle act as a slide "limit", but also give strength to the "structure".
The uses are many and the resulting containers are both reusable and disposable.
Step 1: What You Need
1 ea 2L Pepsi bottle
1 ea 2L Coke bottle or similar.
1 ea Utility Knife
AstralQueen says: Apr 14, 2009. 5:04 AM
awesome idea!
wiley coyote (author) says: Apr 14, 2009. 4:20 PM
Thanks. Since making this I've discovered, totally by mistake of course, that some Pepsi bottles slide inside each other as well allowing you to use the flanges as a "lock" that actually POPS into place.... with careful trimming of course.
eldavoloco says: Oct 19, 2009. 9:44 AM
 I would love to see a picture of that!
wiley coyote (author) says: Feb 8, 2010. 8:34 PM
I'll try to remember to get the camera before I make the fatal cut too far.
barblind says: Nov 30, 2009. 7:43 AM
eldavoloco says: Oct 19, 2009. 9:48 AM
 Great idea! Simple, elegant, and cool-looking. I especially love the space-age styling of the two bottoms combined.
 On the two-bottom combo, I could see drilling a hole through the center of the top bottom and inserting a drawer pull, to make it more decorative and easier to open. Thanks for sharing!
wiley coyote (author) says: Feb 8, 2010. 8:32 PM
Thanks.
Just today I was using this idea for something else and thought of cutting windows into each bottle that can be opened or sealed shut by turning the bottles.
kortez617 says: Jul 15, 2009. 11:45 AM
lol dude thats sick im so doin that
wiley coyote (author) says: Jul 21, 2009. 1:07 PM
Thanks. I also made a bellows for a fire. It works great.
chuckr44 says: May 1, 2009. 8:36 AM
Ok. Here's my collection of plastic bottle projects so far.
http://home.comcast.net/~chuckr69/bottle.htm
wiley coyote (author) says: May 1, 2009. 5:53 PM
Nice. A noble cause, indeed. I like the words ".... so far".
chuckr44 says: Feb 12, 2009. 9:00 AM
Someone should make a website with all the ideas (or links or pics to) uses for used plastic bottles. I wonder if this idea will help my son get a merit badge in boy scouts.
wiley coyote (author) says: Feb 12, 2009. 4:00 PM
At the very least, he'll be able to safely transport smore supplies ... all else is secondary.
kcli says: Jan 10, 2009. 6:51 AM
Very Clever! This could translate into an ideal storage system for organizing supplies/hardware as a result of...1)You can quickly see what is stored; 2)if they fall off a shelf the container will not shatter and contents will likely remain inside; 3)the container can be cut to a similar size so the arrangement looks tidy. I love it!
wiley coyote (author) says: Jan 10, 2009. 12:29 PM
Thanks. Thinking outside the "container"! I like it.
bruno13069 says: Jan 9, 2009. 2:27 PM
The threading on a 2-Liter bottle is the same as a standard garden hose here in the U.S. Take a bottle cap, and poke a small hole in it with a hot nail. Screw it onto the end of your hose and PRESTO! You have a higher pressure stream. Great for rinsing out the cracks in concrete before patching.
wiley coyote (author) says: Jan 9, 2009. 2:58 PM
Thanks, I did not know they are the same thread. Useful stuff to know for hydroponics.
bruno13069 says: Jan 9, 2009. 3:35 PM
A buddy of mine used a 2-liter bottle, a garden hose, a trigger sprayer, some clamps, some duct tape and a 3 level stairwell to make the biggest beer funnel in the area.
I never tried to drink from it, but it was entertaining watching others attempt to do so. 30 feet of gravity on a vertical shaft of liquid can be messy.
I do not recommend that anyone at home try this.
altomic says: Jan 9, 2009. 7:59 PM
would you recommend trying it at the office?
wiley coyote (author) says: Jan 9, 2009. 6:22 PM
Sounds like an Instructable to me. You probably wouldn't have much trouble finding helpers for the testing process.
Chicken2209 says: Jan 9, 2009. 12:37 PM
learn something every day
wiley coyote (author) says: Jan 9, 2009. 12:50 PM
Makes the day worthwhile.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
