3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
2n3055 flyback transformer driver for beginners
Intro:
This instructable will show you how to make a cheap and simple driver circuit in order to get high voltage arcs out of a component called a flyback transformer.
A flyback transformer, sometimes called a line output transformer are used in older CRT TV's and computer monitors to produce the high voltage needed to power the CRT and electron gun. They also have other auxiliary windings built into them that the TV manufacturers use to power other parts of the TV, so they are usually customised by the manufacturers.
For the high voltage experimenter they are used to make high voltage arcs, which is what this instructable will show you how to do with just a few simple electronic components.
You can get flyback transformers out of older CRT monitors and TV's. They are the ones that have a big heavy chassis. There are also other instructables on this website showing how to remove them from the chassis and circuit board.
Disclaimer
I am in no way responsible if you mess up with this circuit. If you mess up you have no one to blame but yourself.
What you will need:
1x Flyback transformer
1x 2n3055 transistor + heatsink
1x 220 ohm 5 watt resistor
1x 22 ohm 2 watt resistor
(Note: The resistor values do not have to be exact. Say if you had a 33 ohm and a 200 ohm resistor they would still work fine for this circuit).
Some enamelled magnet wire, single core bell wire also works well too for the primary and feedback coils.
A fast diode. Although this is not needed for the circuit to work, it protects the transistor from back emf spikes and can help prolong the life of the circuit. I just used the one I found on the TV board but the UF4007 is an easy one to get hold of in electronic stores if you need to buy one.
+Some way of connecting the components
such as alligator clipped cables or wire and solder.
You may not, except with our express written permission, distribute or commercially exploit the content. Nor may you transmit it or store it in any other website or other form of electronic retrieval system.
Step 1Mount the transistor onto the heat sink
Mount the transistor onto the heat sink. The heatsink is important as the transistor gets hot. I just bought the cheapest heatsink maplin sell. The 2n3055 is a TO-3 case style.
You can use an insulator pad if you want but I just used a small amount of old thermal grease I had lying around. To mount the transistor to the heatsink I just used some spare screws and nuts I had in the garage.
Make sure that the transistor pins do not physically touch the heatsink and it is screwed in securely.
Q: Can I use a different transistor?
A: Yes you can, as long as the transistor has similar specs to the 2n3055 or better.
Q: Can I use a PNP transistor?
A: Yes, but you will have to reverse the collector and emitter connections in order for it to work. It will also need to have similar or higher specs as the 2n3055 transistor.
Q: Is the heatsink really needed?
A: Yes, if you are wanting to use this circuit for more than a few seconds the heatsink is vital as the transistor will get hot fast.
Q: Can I use a MOSFET?
A: No, a MOSFET will not work for this circuit.
79 comments
1-40 of 79next »
May 11, 2012. 9:21 PMR.A.T.M says:
So i have a big problem i here a humming out of the coils and when it will not arc and if you look at the transistor theres a flash inside then transistor and the humming stops
Apr 30, 2012. 4:39 PMnms22 says:
I have made this circuit successfully and am running it off 12 V at 1.7 amps. I have a fairly large heat sink on the transistor, but it is still "frying". Is this because of it receiving an EMF pulse, or is the current simply too strong for it? Also, does anyone know the temperature limits of the transistor used?
May 1, 2012. 2:01 PMnms22 says:
Thanks I'll have to try that! At the moment I'm using the 2N3055 NPN transistor according to the schematic on this website: http://www.angelfire.com/80s/sixmhz/flyback.html (Same as your design, I believe). I've wound my own coils, being that the ones already present were not working very well for some reason. And as for the frying transistor, perhaps I'm also not using a big enough heat sink, but its larger than the one you have in the pictures above. Another thing I've heard is using a diode on one of the transistor leads, but which one is it? Also, do you know if this actually helps? That seems that it would be the easiest fix, but I don't want to try it right away and blow another transistor unless it works. I'm looking to be able to run the flyback for more than just a few seconds at a time, so I definitely have to try one of these methods.
Feb 19, 2012. 3:51 PMAj96 says:
I am getting a high pitch noise from the flyback transformer, but i am not getting any arc from it, any advice on what to do?
Feb 10, 2012. 6:40 PMR.A.T.M says:
that arc is loud ouch me ears
Feb 11, 2012. 10:01 PMR.A.T.M says:
Umm the 1 titled simple 2n2005 flyback driver its screaming really loud height pitch
Feb 12, 2012. 6:39 PMR.A.T.M says:
on the video or in real life the video camera may pick up more than humans can here and some people have a wider range of hearing so what i may here you may not
Sep 25, 2011. 7:47 AMdanton721 says:
This is plasma, right?
Mar 30, 2012. 10:03 AMdanton721 says:
This plasma has power to cut some thing? (like a cnc plasma cutting)
Jan 31, 2012. 6:22 PM-max- says:
poke holes in paper (and burn it) and thin rubber is about all.
Sep 27, 2011. 9:06 PMmoparman says:
You rarely need to scrape the enamel off of magnet wire anymore. They have been putting "solder through" enamel on this kind of wire for many years now. You just need to hold the soldering iron on the wire for a few seconds longer than usual. This is particularly helpful when using very small guage enameled wire.
Gene
Jan 31, 2012. 6:37 PM-max- says:
ioll try that, i found it works somtines so far, ill try holding it on longer
Jan 25, 2012. 4:42 PMDunharrow says:
will u always get a plasma for the HV out or does it vary upon voltage input
Oct 24, 2011. 5:32 AMZygOhm says:
When I combine the scheme 5 volts everything works fine, but when I connect a 12 volt, my transistor 2n3055 burns.
Maybe someone here knows what kind of trouble?
Thank you
Oct 28, 2011. 7:23 AMZygOhm says:
Yes. I'm using a heatsink.
Oct 29, 2011. 7:38 AMZygOhm says:
it even not getting hot. When i connect 12v i'm just hearing some cracks from transistor (no arcs). And then i again conect 5V  - nothing happens.
Sep 25, 2011. 10:11 AM5>2G0@5=:> says:
(removed by author or community request)
Sep 25, 2011. 11:29 AM5>2G0@5=:> says:
Driver on 2n3055 very simple... even for beginners. Better to make scheme on NE555 and IRF transistor. Sorry for my grammar if I have any mistakes ;-)
Oct 22, 2011. 2:58 AMmoris_zen says:
You are missing a diode in revers polarity over the supply .
Try connecting one (in parallel to the supply) anode to the minus of the supply.
This should take the current from the main coil during switch off and prevent overloading the FETs .
Oct 22, 2011. 2:06 PMmoris_zen says:
Wrong location - needs to be in input to the coil (parallel to coil) in revers to power .When FET is off the current from coil will go via it and not burn the FET.
Sep 25, 2011. 12:06 PM5>2G0@5=:> says:
It depends how do you place all components on the plate and how do you link them. It's bad that you don't know Russian, because our amateurs work a lot with MOSFET and NE555. Try to use google translator at least to look at the scheme.
Sep 25, 2011. 12:18 PM5>2G0@5=:> says:
I use scheme with 555 and MOSFET. It works 1 year without any problems. Later I'll send you photo and scheme if you want. And now I want to make something more powerful, for example like this http://www.instructables.com/id/ZVS-Driver/
Sep 25, 2011. 12:40 PM5>2G0@5=:> says:
If you give me your e-mail, I'll send U scheme and photo, ok ? But little later, because I'm at the students hostel, and my device at home. Next holidays I'll make some photo and send you, ok ?
1-40 of 79next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:Alex1M6(Visit my YouTube!)
Me on YouTube youtube.com/Alex1M6
