Step 2Preparing the flyback
11 turns primary and 7 turns feedback is a good starting point but you can try more or less windings to see what gives the best results.
Using a sharp knife carefully scrape away the enamel coating from the very ends of the magent wire.
Once you have wound the coils and removed the enamel at the ends of the wire check for continuity using a multimeter, doing this can save you lots of bother later on!
You do not need to worry about finding the HV return pin yet.
Gene
All the magnet wire I have purchased from my local electrical store has required me to scrape off the enamel before soldering. Even with my coil gun project where I was using voltages of around 300V with the magnet wire I still had to scrap off the enamel in order for any current to start flowing.
