Step 7Finding the high voltage return
Bring the chicken stick close to the base pins on the flyback and go past each one individually. Some of them may give a slight spark but one of them should give a solid constant HV arc, this will be your HV return pin. You should now disconnect your chicken stick from the HV out and connect it to the HV return pin instead.
In the image's above are some arcs produced by my 2n3055 driver and some different flyback transformers, most flybacks will only give around a 1-2cm arc on 12V input and upping the input voltage only increases heating on the transistor in my experience.
Have fun and remember not to run this circuit for periods longer than 1 minute as the transistor gets hot fast.
Add Comment
