Introduction: $3 Air Filter for Scooter
Picture of $3 Air Filter for Scooter
Hi guys! Another thing about scooters today. Today we will replace scooter 'lungs' - air filter.
Air filter is very important thing in your scooter. If it will be too old carburetor will start sucking air with dust in it. Sooner or later it will cause engine failure coz dust will go direct into the cylinder. It is also can block carburetor.
So today we will change our old filter. Lets do this
Step 1: Buying, Cutting, Fitting
Picture of Buying, Cutting, Fitting
For the new filter we will need a foam sheet. I bought one for $2.99 in our local (New Zealand:) shop which sells lots of plastic stuff. Plastic World or something. Size is 30x30mm, thickness is 25mm.
Important thing. Do not use foam with PPI (pores per inch) less than 60. Perfect foam for filters should have PPI from 60 to 80. Foam with PPI less than 60 will let small pieces of dirt go through into carburetor. If PPI is more than 80 it wont let air go through the filter fast enough so it will be a bit hard to start the engine.
Cut the foam to the shape you need.
Step 2: Oil It
Picture of Oil It
Its very important to oil your filter. Dry filter wont make any difference.
You can use almost any kind of engine oil: 4 stroke, 2 stroke, etc. Just not cooking oils ;) Or buy foam filter oil.
I use used motor oil which i drained from my car few days before that. It wasnt too old (car only done like 10k) but i still would recommend you to use fresh oil.
Pour oil on your filter and spread it with paint brush. Make sure that oil is not dripping from the filter. Squeeze it couple of times and install to the scooter filter.
Job done :)
Good luck!
USMC-USAF-USN (author)2016-01-10
Very good information - thank you. The same principles can be applied to lots of other things with foam filters on the air intake. (Like my air compressor ... )
all good mate. glad you found this information helpful. cheers
About This Instructable
996views
1favorite
More by That_scooter_guy:$3 Air Filter for Scooter$20 Surfboard Rack for scooter. Take twoCheap LED headlight for scooter
Add instructable to:
