Introduction: 3 Amazing Daily Life HACKS DIY
Hello friends
Today i will share something like which you going through day today life and you never know before how to hack them to make your life easy.
Here i am showing 3 hacks to make your life easy
1) Making pin for 9V DC from dead battery.
2) How to generate electricity to charge your mobile.
3) How to charge your mobile when there no charging point are available or occupied.
Please watch video in the last step of this instructables
and friends don't forget to subscribe our channel on youtube.
Step 1: Video of All 3 Hacks
Friends watch video for this amazing daily life Hacks
Like us, subscribe us, share us
For detail instruction please go through step by step of this Instructable.
Step 2: Making Pin for 9V DC From Dead Battery
So you have a 9V dc battery but you don't have its pin
it is very much difficult to use this type of battery without pin so lets make our own pin
using old dead 9V DC battery
Now bring dead battery from scrap open it remove it pin portion
now solder wire in back side of that pin
now its ready use this pin press it on your battery and connect wire where you want to
give power.
Material required
- Two 9v battery one dead & one is healthy
- cutter
- some wire
- soldering iron
please watch video of this instructables
Step 3: How to Generate Electricity to Charge Your Mobile.
So you have a discharge mobile electricity is not there to charge what to do now ?
I have a solution !!
Bring or cut micro USB pin this cable have 4 wires inside
keep RED & BLACK one and cut all others
now connect this two wire with pin of DC motor (gear motor for higher RPM)
now connect a wheel on shaft of the motor to rotate shaft
now rotate wheel slowly slowly by doing this DC motor will
move very fact due to gear in between and generating DC Volt at its terminals
so your mobile start charging
Material required
- Micro USB pin
- Small DC gear motor
- Wheel to rotate DC motor
- Some wires
- Double side tape
Step 4: How to Charge Your Mobile When There No Charging Point Are Available or Occupied
So you have a discharge mobile but no charging point are available what to do now ?
Simple plug your charger into the lamp holder your mobile will start charging.
Material required
- A mobile charger
- A lamp holder
